Results 1 to 7 of 7
Thread: How to create directory list in skin ?
    Aug 2004
    Germany
    Hi,
    I'm working on a skin and want to include a directory list (as you find it in most skins in the audio browser). I tried copying the correspondending line of other skins, but I can't get it to work, it doesn't show anything. When I load other skins it works there as it should.
    So how does it work ?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    List properties in Road Runner skins
    First Download the latest beta of Road Runner, as it supports the new commands in the SD line. Just Download the Road Runner.exe and replace your with it.
    Try these lines:
    Code:
    /, S, x, y, w, h, fore R;RGB, G, B,  back R;RGB, G, B,  folder R;RGB, G, B,  file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
    S01,114,110,575,262,255,255,255,255,255,255,255,255,255,255,255,255,255,255,255,0,0,0,TRUE,20,"Arial Narrow:B"
    /, SD, Alignment;Alignment, Disp;MODE, Icon Width, Icon Heigth, Path
    SD,00,01,50,50,"C:","*.*",1
    The second line SD shows *.* to show ALL file types. If you just want music use *.mp3
    My Fiero Build Thread
    Aug 2004
    Germany
    Hi. First, thanks for your answer. I still have a question though:
    I will have
    a S01,......-Line for displaying the playlist and
    a S02,......-Line for the directory list
    In the S01-Line you postet, how does RoadRunner know that this should be the are for the directory listing, and not for the playlist ? I just see coordinates, size, colors, and font there, but no description, that this should be the directory-area.
    As you can see I don't totally understand this command .
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    Is there a way of showing a directory list WITHOUT any pics?
    I mean no folder icon, no file type icon, no album art... NOTHING, just the directory list
    just like the playlist look
    more:
    is there a way of putting some of highlighted (selected) song tag in the directory list on a label?
    another for u gurus:
    is there any label code for lists current number and/or total? I know that there is such labels for PLAYlists. but could not found it for ordinary lists. it would be nice when browsing not yet loaded large dirs so u can figure out how far from top or bottom of the list u are (the same as in PL)
    []s
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by will_santana View Post
    []s
    Yes, but it'll affect ALL your directory lists in your skins.
    In rr.ini, set showicons=0.
    Also, by using that setting, you will not be able to use thumbnail views for your directories.
    Is there a way of showing a directory list another for u gurus:
    []s
    DLPOS to show your current directory position. For total directories in a give path, I don't think there is a code for that. However, you can set a label to display a value or code using BYIND and TOPDL. Not a complete answer to your question, but best I got. You could also make a DL slider to show your directory position.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You need to read the BIBLE....
    SkinCommands.txt is your friend.
    Everything you want to do is explained in there.
    "PLTEXT" - Shows the text currently selected on a playlist
    "DLTEXT" - Shows the text currently selected on a Directory List (Folder list)
    "DLPATH" - Shows the current path on a Directory List (Folder List)
    "PBTEXT" - Shows the text currently selected on a Phone Book List
    "PLPOS" - PlayList Position (can also be polled directly from flash -- see below)
    "DLPOS" - Directory List Position (can also be polled directly from flash -- see below)
    "PBPOS" - PhoneBook List Position (can also be polled directly from flash -- see below)
    "LISTTEXT" - Shows the text selected on the currently selected list
    "LISTPOS" - Shows the Current Item Position in the current list
    Mar 2007
    thank u guys
    I always program with skin commands.txt and RR help open
    but as I said in other topic, I think RR documentation REALLY needs a review
    I have no doubt that RR is most powerfull and configurable front end. But the documentation is kinda confuse. there's no clear examples, cross references and such things
    I've already ofered myself as a volunteer to try putting it together. But I don't really think I already know enought of RR to do a real good job on that
    I'll try to do this test skin I'm working on just to get more knowloge than I plan to work on documentation
    Thanks once more for the fast replies
    []s
  1. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  2. Chucks Song Reminder list skin
    By Chuck in forum Road Runner
    Last Post: 10-12-2006, 08:02 PM
  3. Alignment of the Directory List
    By liquid_smoke in forum RR Bug Tracker
    Last Post: 05-07-2006, 09:51 PM
  4. how can I create my own skin?
    By Frankino in forum FrodoPlayer
    Last Post: 12-22-2004, 10:13 AM
