Results 1 to 6 of 6
Thread: regarding a 40x4 character lcd and visualizations
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    ive ordered a 40x4 character lcd and i have gotten a hold of a winamp plugin which will output a spectrum analyzer and other id3 info to it. the problem is, winamp considers this character lcd as a visualization, so i have to choose the plugin for this character lcd instead of my normal AVS plugin. anybody know a way to use two visualizations? or a place with software that can control my character lcd? i have found software to do control the lcd and put in winamp info. however the only thing i can find will output only the track info (not artist/album and spectrum analyzer). i know its a weird request, but does anyone have a way around this? thansk
    EDIT: just realized that i posted this in the skins section. oops. sorry. didnt mean to.
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    you be better off using LCD Smartie, got some nifty features and great winamp / system screens... verey configurable check it out, im using it, and i knowseveral others too, they even got their own drivers in the latest versions...
    LCD Smartie
    Mar 2006
    Houston, TX
    thanks, ive already downloaded that, but ill explore some more.
    Mar 2006
    Houston, TX
    umm, yea that uses a winamp plugin too. im beginning to think that a spectrum on the 40x4 is not possible without the plugin. cant i get track info from winamp without running a plugin tho?
    Dec 2005
    Skien, Norway
    forgot that...
    there is a winamp plugin that enables you to use several plugins at that same time... dont remeber its name but will do a search for it...
    i know it works, used it earlier...
    Mar 2006
    Houston, TX
    that is exactly what i need. please keep lookin- thanks
  1. Problem with a 40x4 Parallel Port LCD
    By SuperAJ in forum LCD/Display
    Last Post: 06-20-2003, 08:22 PM
  2. LCD view angle and other question...
    By salmonslapped in forum LCD/Display
    Last Post: 10-28-2002, 06:16 AM
