Results 21 to 30 of 37
Thread: RR Skin Checker v1.0.3
  1. #21
  2. #22
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Enforcer View Post
    Care to explain a bit more?
    I remember a few times getting the "black bar" or the skin wouldn't start at all, I would say to myself humm..what the hell is going-on (while scratching my head!)? Ah, let me run skinchecker.
    It would tell me that (image) menu_on.skin which cause me to look for it only to find it was just misspelled (mennu_on.skin). Sometimes the graphic was missing all together.
    External_GPS.skin was always missing the underscore!
    All this cause me to scratch my head wondering what was wrong - until i ran skinchecker!
    With this version i hope to trim a lot of fat (unnecessary files and images) in some skins.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  3. #23
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by will_santana View Post
    the work with RRConfig would save bluezx3 from some extra work
    he could just call your app and get a return code with the state (invalid or missing file - the others are irrelevant to config)
    i'm just trying to bring things together and make all the great parallel jobs to be used in all it's potenciality
    []s
    I would say what will is getting at really isn't all that bad of an idea. It is along the same concept that I believe that the config should be about. Not just something that just allows users to set options but also make sure those setting coincide with the host app, computer, skins...ect. Like window sorta, you hve the installer, then comes the task of setting options and doing a final check to make sure that it works the first time around.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #24
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well most skins will 'work' as long as they have a general.ini and menu.skin, anything is just a matter of some screens not working.
    Now if you want to check whether RoadRunner will actually start those are all you need to check for.
    However parsing the whole skin and then saying it won't work just because the odd jpg or png is missing will probably mean none of the skins out there 'work'.
    However if you want to tell me what sort of reponses you would want if your config called the skinchecker I can look at implimenting that for you.
  5. #25
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by treetop777 View Post
    OK, that is just what I was hoping to hear, as that is the whole reason for me doing it. Coz I was having similar issues.
  6. #26
    Constant Bitrate will_santana's Avatar
    Mar 2007
    Rio de Janeiro/Brasil
    Guess config just needs 3 skins states info:
    1 - Valid
    2 - Invalid
    3 - Working, but bad
    The third state can mean a lot more to skins developers, and that's the motivation for this skin checker
    That's just a matter of what's important in each particular situation
    If every single piece of software made for RR can work together, than we will have something like a ant farm, where each ant do it's job to make all the system work together as a live organism
    gotta some other ideas... but gotta talk to guino first
    believe me when i say that some small coordination can make RR the better (forever FREE) frontend EVER
    []s
  7. #27
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Great, now we're being compared to ants?? LOL
    I think that would work, and just calling the skinchecker with a param of the skinpath to check. Maybe have 2 valid states, one thats used for non png'ed skins and the other with, so I could make sure that if a png skin is selected then make sure that fastmode is using gdi+. Just trying to elminate less questions like "I just installed this skin, and now all I get is.....how do I fix it?"
    It would really be nice if we did have some storta standard, like all plugin's in the plugins folder, that would have made it real easy to also be able to config the plugins right from the config as well, but there is no standard so when people do make a plugin they just have you put it in what ever folder instead of having everything in one place. just like WA, every plugin that you add all go's into the plugin folder, duh...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  8. #28
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Hmm, png or no png, that would be easy, however deciding on which png makes it a png dedicated one. What if someone had pngs in there for another reason?
    One question is, what difference does it make if you run a non transparent skin in the fastmode that is for Transparent ones?
  9. #29
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Its a one way street, you can use non transparent(jpg) skins in what ever mode you want, but you can not do the same with the png's, which is where the user questions come from like in the above post. As there are those users that don't like to read and then post about a prob b/c they don't know what is the correct setting(s) to use with what they "think" the prob is... this is hopefully where my config would catch it before hand and help to get things set correctly so the user can continue with the next problem, whatever that might be...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    So maybe the default should be to use the new fastmode then.
    Unless there is a disadvantage to using it when not using pngs?
    Just like the default for gestures should be off
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Wanted: RR Skin Programer, Pays good!
    By swwesq in forum Classified Archive
    Last Post: 12-22-2006, 01:04 AM
  4. Replies: 3
    Last Post: 03-20-2006, 10:32 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
