Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: RR Skin Checker v1.0.3
  1. #31
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Enforcer View Post
    So maybe the default should be to use the new fastmode then.
    Unless there is a disadvantage to using it when not using pngs?
    Just like the default for gestures should be off
    The default is not to use GDI+ cause not all machines support it (also, the dll needs registering).
    There's no disadvantage using JPGs on GDI+, in fact I think its even faster too.
    Regarding gestures.. doomed if you do, doomed if you don't.. I'm sure by setting it default to off, that the questions would be "why I can't use on screen "drawing" commands on my RR?" :P
    Ride Runner RR's Myspace
  2. #32
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    How can someone tell if their machine does not support it?
    BTW you got any documentation on your GDI+ dll as I might want to try to get my plugins stealthable
  3. #33
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That is currently the default setting (gdi+) but that doesn't stop them from changing it. And don't have to worry about the reg thing either
    Gestures, you mean you don't like them or like reading posts about "what is it" or "how do I get rid of them.." lol
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  4. #34
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    It just dawned on me that if for some forsaken reason they choose it and they don't have the dll file, that there is no check for that...hmmmm (added to next update..)
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah, I change/add so much stuff to RR it's too much of a choir to update the base plugin.. I honestly hope the Extension plugin interface to replace it all.. anyway, to answer your question.. the GDIPlusWrapper I got from that VBAccelerator website.. so you can download the sources there and see all the properties, inner workings and such.. the thing is, there were a lot of BUGS in it.. so I had to fix it up first.. but the functions are virtually the same I believe.. Still probably easier to strip down the code of RR than to add/change the code to the base plugin...
  6. #36
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by guino View Post
    Well I don't actually use your base plugin for my plugins/programs. I started from scratch and worked out my own way of doing the skinning using your/coyote's skins as template.
    I have looked at the wrapper from VBAccelerator and the RR source and am not sure what I am looking at, at the moment. .
    I was hoping you could just copy the relevant parts from the RoadRunner code so I could look at what you added and what references the .dll without all the other stuff around it. IE get that spoon out and feed me
  7. #37
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK so if the GDI is the default and as Guino says there is also benefit to having normal skins run in that mode there is no need for skinchecker to tell you what sort of skin it is.
    However what you need is a check for whether the system can use the GDI stuff, a question which guino neatly side stepped. :hmmmm:
    As far as gestures go I originally hated them as I don't use them, however I have started to use them, there is no only two things I don't like about them.
    1. having to go through my skins to add NG areas to certain parts of them.
    2. The how do I get rid of them, what are these alien space blobs on my screen questions.
  1. EniCar the RR Clone
    By enitalp in forum Software & Software Development
    Last Post: 12-13-2008, 06:12 PM
  2. Mauri RR skin
    By mauri in forum RR Skins
    Last Post: 12-06-2007, 10:50 AM
  3. Wanted: RR Skin Programer, Pays good!
    By swwesq in forum Classified Archive
    Last Post: 12-22-2006, 01:04 AM
  4. Replies: 3
    Last Post: 03-20-2006, 10:32 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
