looks good. I think the text should be a bit bolder.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Win7 with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:IG2k9
Screen:Xenarc 700TSV
The Florida Meets Thread
I like your graphic design skills, but you seem to have two menus (LHS and centre - why?) it doesnt make any sense.
maybe think about what you want first, how it will be laid out etc, scribble each screen down on an A4 sheet, and only then have a go at the Photoshop stuff.
Nice, but I think you need more contrast between the background and text or it may wash out in the car.
So, pretty much![]()
ok i got the clock working, might have to change it to a different design, and i bolded up the text a bit
Ummmm.....
don't like the clock.......
Seems out of place on a fairly clean skin, getting kind of cluttered. But I prefer the minimalist approach anyways. Just me, it's your skin bro, do as you like!
Cheers
BJ
Clocks to me are worthless. Especially in flash. RR has a time label you can add if a time display is wanted.
The status box at the bottom where it displays stop and other stuff seems to be a little squished along with the song title running in to it. Maybe creat a border around it and use smaller fonts. This would clean that up pretty nice I think. Otherwise keep rockin' it
New Age Garmin - Skin for RR
I can do you a custom version of my clocks where you can change the colours etc to match your skin. I can also remove the out ring if you don't want it.
More details can be found here - New Road Runner Clocks/Logos (By Tissy)
Contact me by email / PM if you want to discuss.
Regards,
Steve
System - Epia SP13000 for Main PC, Holux GR-213 USB GPS Receiver SiRF Star III, 2.4Ghz Uplink with VNC and Custom designed USB Intelligent SDC (In DEV). All fed to a Sony CDX-F7500 Headunit via USB. www.wrx-carpc.co.uk
