Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Beta testers for Sony FSR flash skin needed
  1. #11
    Sep 2006
    Sydney
    noOOOOo im too late..
    dammit. i really wanted to give my new 1.6celeron mini pc a push.
    Common, i wont tell if you dont.
  2. #12
    Jan 2007
    Thumbs up Testing...
    Great skin, No issues running flash. Great instructions, installed fine.
    On first load and with an empty play list I have a picture of freedom’s skin where the album art should be.
    The BBAA feature works great, however could be improved by displaying 2 rows of images maybe. The search keys only work for the first character, ie to search for “d” I should be able to press the “cde” button twice, but only once works.
    Everything works on the audio player skin, however could do with a clear playlist button, and maybe on future releases a feature to save playlists. On the audio browser, all works, but again the facility to add just one song would be great, or like freedom, only select the song pressed unless “load all” is enabled.
    Can’t test the GPS screen as the software I use requires full screen. It can’t be embedded.
    DVD works fine, but would be nice to be able to browse for videos
    When I use the web skin, seems to work ok, issues with the keyboard. I used it to type www.google.com however ended with “w.lle.cm”, does the same if I use the onboard ”www” button
    All the main1 and main2 screens work, games, apps etc are fine.
    I’m not sure about the load screen, in my opinion it takes to long, granted it looks good, but a simple option would be nice, similar to freedom’s roadrunner logo…
    Overall a very good skin, clearly a lot of work has gone into it. Well on the way to a final release. Will test some more over the next few days and post results.
    Keep up the good work….
  3. #13
    Constant Bitrate venealis's Avatar
    Apr 2006
    Richmond, VA
    looks good only problem that i'm having is that everything is so small. I've got a small 7" screen and the distance that i sit away from the screen makes some things really hard to see. Other than that looks good.
  4. #14
  5. #15
    moahdib's Avatar
    Jul 2000
    Quote Originally Posted by ger_uk View Post
    Loader screen is already optional as stated in the instructions.. you just have to open menu.skin and change main.swf to main2.swf
    Video browse is there, click on the top right small screen area. Not so intuitive I might try to find a better location for it. I'll check out the other features...Can anyone confirm the problem with the OSK? I think this might be a regional setting issue since you're in UK.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
  6. #16
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Thumbs up
    Great, great skin PERIOD. Instruction is nice and clear.
    After spend good serveral hrs to change to my need, I found serveral issue (or feature )
    - I can't get the spectrum visual to embeded in the area. It's kinda hidden behide the skin.
    - On menu skin: miniarea, I changed to removed album art inplace of sats.swf, but album art is always there and flashing (I know I can stop it by click on it.) Other screen it rotate fine.
    - Dynamid VolUp, Down, Gramma (mute instead ). I can change that but the mute is always mute regardless of command. For example in GPS (iG) screen, I change to Zoom In, Zoom Out, GPS Info. Zoom does as suppose to but not GPS info.
    - RREarth skin: rrearthaddon.swf is not included in the download package. Also, you have to change the jpg file on top of the file to background.jpg. Otherwise, it will look like a "vertical mail slot" because rrearth.jpg is not there.
    - Pic Viewer, nice but a little too fast on slideshow, if there is an option to change interval time, it will be great.
    - Sidebutton, if I change this code from
    Code:
    &sidebut2=NAVI@GPS@icons\gps.png@SENDKEY;{DOWN}@SENDKEY;{UP}@SENDKEY;{G}&
    To
    Code:
    &sidebut2=GPS@GPS@icons\gps.png@SENDKEY;{DOWN}@SENDKEY;{UP}@SENDKEY;{G}&
    I don't have sidebut21 feature. Basically, SideButton 2 doesn't toggle.
    3 Optional buttons is great feature as you can customize it to what you want. I really like it to be available to any screen associate with mainbutton and other button that load skin instead of limit to sidebutton.
    Greate work
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #17
    moahdib's Avatar
    Jul 2000
    Quote Originally Posted by MatrixPC View Post
    Code:
    To
    Code:
    Greate work
    - If the VIS does not embed on any of the screens, make sure the exectbl.ini has the following line:
    "WVIS","RUN;;!attachanalyser"
    And from the mainbut or sidebut, you need to run WVIS after the load skin command.
    - In menu.skin the flash in miniarea isn't meant to change. I think i did that for a reason (performance) as it slowed the skin down too much and took too much cpu usage. I'll play around with it again and see if i can re-enable that.
    - You can only change the vol up, down and gamma. The mute always works as mute as well as the repeat/shuffle button. They are a on/off state button. Maybe i'll incoroparte them in later version
    -I never tried rrearth... I'll see if i can dig up those files and include them in the release.
    - Option to change interval will be added.
    - The sidebut toggle I am talking about is between sidebut2 and sidebut21. The 3 sendkey commands you have there are for the vol up down and gamma buttons.
    My TL CarPC ver2
  8. #18
    Sep 2006
    Looks like a great skin. Keep it up. I remember your posts on acurazine moahdib. Glad to see your still around. I'm in the final testing of my Carpc before I install it in my 05 WDP TL. I'm willing to give this skin a try.
  9. #19
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Would like to test
    PM Sent. I would love to test the new skin!
  10. #20
    moahdib's Avatar
    Jul 2000
    Just a heads up this is very near to completion now if nobody has any more bugs to report.
    My TL CarPC ver2
  1. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 10:21 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. flash skin preview
    Last Post: 07-09-2005, 05:17 AM
  4. FSR and Flash?
    By juve021 in forum FrodoPlayer
    Last Post: 03-18-2005, 03:23 PM
  5. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
