Originally Posted by
obrienj
RPM-VR4,
Thanks for the explanation. Given that Visio, PS, and Paint can read these .png files, what is the technique you use in skinbedder to read and display them?
As you well know, accessing location 0 can mean a varible isn't initialized, a function failed but that was not detected, and a whole bunch of other things like that.
Can you determine if the error is in your code or in some library routine you call?
As I have the time, I would be willing to look at the code as long as it is in Java, C, C++, or VB
I tried the select all->new->... thingy with no joy. Also, Visio can load one of the distributed nRoute .png files, but can't break it down into it's component parts. On my .png file, it can. But that shouldn't matter as at the point you are using it, it should just be an image that you display and may or may not resize.
Anyway, if I can help let me know, This is a potential "show-stopper" for me as I need to build several interfaces and SB seemed like the way to go.
Regards,
Jim
