Page 2 of 12 FirstFirst 1234567891011 ... LastLast
Results 11 to 20 of 111
Thread: nRoute skin (in progress)
  1. #11
    Jan 2006
    RSA
    What window/class names did you use for the find places window?
  2. #12
    Apr 2005
    S.A.
    same as the nag screens
    #32770
  3. #13
    Jan 2006
    RSA
    Hmm, I did try that, but no luck, will try again later, thanks
  4. #14
    Apr 2005
    S.A.
    Quote Originally Posted by alfash
    give me an email address and i will email you everything i got so far, maybe you will get more time to play. i had to change other screens aswell.
  5. #15
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    ...subscribing. It sounds like you have figured out how to use my program SubaruWRX (probably one of the few LOL). Any specific questions? Post some of your INI with [ code ] ... [ /code ]. I will help all I can though I don't have a copy of nRoute.
  6. #16
    Apr 2005
    S.A.
    Quote Originally Posted by RPM_VR4
    thanks for the vote of Confidence, but all i did was read the readme file and pull apart your iguidance files. when i have finish i will start to rename all the file for nroute. i will take you up on your offer when i hit a wall, but for now i am ok. i was only trying to help ALFASH with his problem, i use one of the small keyb from the store for my input, i find it much easier when driving.
    It is an excellent program, keep up the great work.
  7. #17
    Jan 2006
    RSA
    OK, haven't had much time to play in the last few days, managed to find my embedding probs though, misnamed the "enterstreet" dialog - thanks for the files . I see what you mean about the loss of focus, my OSK gets a character into the text box and then I loose focus, hopefully I'll get some time to play today, will keep you updated.
  8. #18
    Jan 2006
    RSA
    OSK Woes
    OK, seem to see whats happening, i'm getting the OSK onscreen and working as long as the key I'm pressing is not in the area of the Find Places dialog (which is modal), did you expierience this prob/figure a way around it?
  9. #19
    Nov 2004
    L.A.
    alflash: I have no idea what you are talking about. I was hoping Sub would answer. Could you post a screen-shot and a little more detail of the problem? Also attach your OSK ini-file.
  10. #20
    Jan 2006
    RSA
    Osk
    EnterOSK.ini.txt
    OK, I've attached a screen shot (using mercury's keyboard), I've drawn a red line on the image to indicate were the OSK stops working, to the left of the line i get the SKINbedder crosshair and the a key works fine, to the right however, nothing, I think the dialog grabs the focus here. (alsa attached my .ini).
