Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 21 to 30 of 111
Thread: nRoute skin (in progress)
  1. #21
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    I think the problem may be that the OSK skin layer is loading before the embedded sub-window. You could try adding a wait(xxx) in between the Embed() command and the loadskin() command. Start with something huge like wait(5000) and if that works then just reduce the number until it is acceptable.
    A better idea however is to just nudge the bottom of the sub-window up (since you can't really see the part of it that is behind the OSK anyway).
    Let me know how it goes and if you still have trouble, post the ini file for the sub-window and the OnPressUp/Down= statment that embeds the sub window and loads the OSK.
  2. #22
    Apr 2005
    S.A.
    sorry people, i had to go to durban for the weekend.
    ok, after playing for a while i found that to get a OSK that is see through is the best way to see the find window. that part is easy. the hard part is that the map window of nroute updates its self on every find. so when you press find it shows the location on the map and brings that part of the window to focus, if you press the down arrow on the keyb it will scroll through you find list, but the map window stays in front and it updates with the new location.
    i have tried every way round loading the find window, but the map still wants the focus. i think that this is a part of nroute and i can't see a way round cos the nroute main window consists of about 10 differnt window classes but some with the same name. so the only way to do this, if possible would be to embed the map window so you can bring the focus back to the find.
    still trying, lets see.
    sorry, read backwards after posted. alfash, the problem i am trying to fix is the find window losing focus. this is only because when i get that working the osk looks like a matter of getting the ini file right. time consuming, but should be easy. if we can't get the find window problem fixed the osk is the least of your worries. try without the osk, leave it onscreen and just use you keyb, when you press find you should loose the find window under the map. let me know if you get the same problem.
  3. #23
    Apr 2005
    S.A.
    ok attached is a keyb to play with. it has the ini file aswell. if you are using the dir i sent you then just replace in the igenterstreet dir.
    ALFLASH this might also help with your problem.
    p.s. this is a quick OSK just to do some testing, if there is a problem with it let me know.
    Attached Files Attached Files
  4. #24
    Nov 2004
    L.A.
    SubaruWRX: I have moved this thread to the SB Skins folder. Please update your first post with a zip of your entire SKINbedder\nRoute directory so others can download and use your SKIN. Thanks.
  5. #25
    Apr 2005
    S.A.
    Quote Originally Posted by RPM_VR4
    thanks for moving.
    let me do some work on it first, only because it is not in a usable condition. i need to create some graphics. the ig skin that came with i just changed the use of the buttons to use the skin to test, had enough of not having nroute in RR.
    ok check first post and let me know
  6. #26
    Apr 2005
    S.A.
    new update check first post
  7. #27
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Update first post with screenshots
  8. #28
    Apr 2005
    S.A.
    ok new update in first post. the link also has a rar file with screen captures.
    have added all the buttons i think you could use. if there is any other you want let me know.
    Still looking to fix the problem with the find window loosing focus, but to get by for now i have added cursor keys on the keyboards so you can scroll through the finds.
    Apart from the focus problem i think it is almost finished, I hope, let me know.
  9. #29
    Apr 2005
    S.A.
    everyone went quiet.
    whats does people think? i know that the graphics aren't any good but they make do.
    has anyone found a way to fix the problem with the find window loosing focus?
    is this finished or is there anything else i should do to it?
    please let em know
  10. #30
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    hey Subaru,
    got any idea how to get rid of the nroute warning message in the beginning.
    guess you could have an idea 0l33l suggested using Autoit. Do you have the script for it??
    thanks..
    edit: Y does this 0l33l come up instead of your nick???
    i think this forum hates you
    just kiddin.
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
