ok, on the skin i left for downloading it already should take the warning message away, it does on mine. i embed the warning and then accept it. you will find it in the 'nroute.ini' in the root dir.
[Scripts]
;This is the startup script that tells SKINbedder what to run, embed, and skin with.
StartUp=wait(500),Run(C:\Garmin\nRoute\nroute.exe) ,Wait(200),Embed(NRNag:100),Focus(NRNag),Wait(200) ,Send(Enter),Wait(200),close(NRNag),Wait(200),Embe d(NRGPS:500),LoadSkin(NRMap:Menu_Left),LoadSkin(NR Map:Menu_Right)
the 'NRNag' dir is for the warning screen. if it does not work for you try adding a second ',Wait(200),Embed(NRNag:100),Focus(NRNag),Wait(200 ),Send(Enter),Wait(200),close(NRNag)' after the first. i found that some times it works with the second.
like this
[Scripts]
StartUp=wait(500),Run(C:\Garmin\nRoute\nroute.exe) ,Wait(200),Embed(NRNag:100),Focus(NRNag),Wait(200) ,Send(Enter),Wait(200),close(NRNag),Wait(200),Embe d(NRNag:100),Focus(NRNag),Wait(200),Send(Enter),Wa it(200),close(NRNag),Wait(200),Embed(NRGPS:500),Lo adSkin(NRMap:Menu_Left),LoadSkin(NRMap:Menu_Right)
let me know if it works.
LinkBack URL
About LinkBacks
