Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 71 to 80 of 111
Thread: nRoute skin (in progress)
  1. #71
    Aug 2006
    Quote Originally Posted by nemo1 View Post
    Have sent to your emails.
    Nemo, thanks so much for your effort and now to figure out how to merge with zots day skin. This is my first setup. I am not too good at this, any pointers.
    jackdon.
  2. #72
    Aug 2006
    thanks nemo, ive noticed in the find place window when u press a button on the OSK it automatically presses the "Find" button on the find places window, any way to overcome this?
  3. #73
    Variable Bitrate nemo1's Avatar
    Jun 2006
    Quote Originally Posted by jackdon View Post
    jackdon.
    Which front end are you using
    Quote Originally Posted by br34k View Post
    I don have this problem. There might be a solution but I am not aware of it.
  4. #74
    Aug 2006
    [QUOTE=nemo1;908453]Which front end are you using
    Hi Nemo,
    I am using Road Runner with Zot.day skin which I downloaded from the official site.
    Any pointers as I have never done any skin modification before but I learn fast .
    jackdon
  5. #75
    Jun 2006
    [QUOTE=jackdon;908558]
    Hi Nemo,
    jackdon
    Jackdon...its ok.... I am no expert also. Just trying around and sharing knowlegde and findings. Here is what you have to do.
    Goto rrconfig, then click on the GPS tab. In the GPS settings, you will see GPS path. Click on it and a browser will appear, then using the browser go to the folder where you store your SB and click on the skinbedder.exe
    Click open and save. Now in your RR when you go to GPS, you will see nRoute and SB. Try it out, I believe there is a few more settings that you have to work on as I have done so. I have use SB to eliminate the warning message in nRoute and the multiple SB in taskbar when you go in and out of GPS.
  6. #76
    Aug 2006
    i cant get the "Select Street" window to embed
  7. #77
    Low Bitrate 2muchwires's Avatar
    Apr 2006
    Puerto Rico
    What happenned?
    Is this thin dead or moved??? is my newbie instincts causing to lose it? what happened? evry body died?
  8. #78
    Sep 2006
    Can someone let me hava copy of this skin as well - i'D really like to get this embedded in rr somehow
    email? garethjjones at hot mail dot com
    TIA
  9. #79
    Constant Bitrate jeffreyd_tx's Avatar
    Sep 2006
    Wilkes-Barre, Pennsylvania, United States
    Hi,
    Can you send me a copy of skinbedder skin for nroute to the following address. jeffreyd_tx@yahoo.com
    Thanks.
  10. #80
    Variable Bitrate ramy_zohair's Avatar
    Sharjah, Emirates
    Ok guys, here is my version. you are free to alter it in any way you like. have fun. Thanks subaru & RPM for the support.
    I would love to get some feedback.
    http://www.savefile.com/files/78995
    Final Touches
    Car: 2002 Mitsubishi Magna EI
    CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
    Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
