Results 1 to 10 of 14
Thread: Old NetStumbler SKIN (needs a new owner)
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    This was posted long ago.
    I am putting it here for record.
    It may not work as-is. Feel free to improve it and re-post it.
    Attached Files Attached Files
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Alright, I've been playing with it. I changed the skin around, and have a few problems:
    Netstumbler does not embed, unless I am quick enough to click on the 'skin' before NS comes up.
    The buttons don't seem to do anything. They don't change color (skin_down), and they don't send key strokes.
    How do I control the window within a window? I read through the threads, I would search, but I don't know what the inner window is called.
    And finally, but I can live with it, the little message window keeps fighting with SB. I could move the buttons, but that's where I want them!
    Here's what I have:
    -----SB Config:
    [Global]
    DefaultProgram=NetStumbler
    EmbedderRefreshInterval=250
    -----Netstumbler.ini: (C:\Program Files\SkinBedder_v3\NetStumbler)
    [MainForm]
    Caption=SKINbedder NS
    Top=0
    Left=0
    ClientWidth=641
    ClientHeight=390
    BackgroundColor=$000000
    LoadingImage=
    [Scripts]
    StartUp=Run(C:\Progra~1\Networ~1\Netstumbler.exe), Embed(NSMap:500),Focus(NSMap),LoadSkin(NSMap:Skin)
    ShutDown=Kill(netstumbler.exe)
    Hibernate=Focus(NSMap),Send(Alt-B)
    Resume=
    -----NSMap.ini (C:\Program Files\SkinBedder_v3\NetStumbler\NSMap)
    [NSMap]
    WindowClass=
    WindowTitle=Network Stumbler
    Width=
    Height=
    TopBorder=0
    LeftBorder=0
    RightBorder=0
    BottomBorder=0
    NudgeUp=0
    NudgeLeft=0
    NudgeRight=0
    NudgeDown=0
    TransparentColorValue=
    AlphaBlendValue=
    Visable=True
    -----Skin.ini(C:\Program Files\SkinBedder_v3\NetStumbler\NSMap)
    [Skin]
    TopBorder=335
    LeftBorder=0
    RightBorder=
    BottomBorder=
    Actions=New,Open,Scan,Save,Exit
    ;OnClick and will occure only if there is not a button in that area.
    OnClick=BringToFront(NSMap)
    ;OnDrag can be set to MoveWindow, CloseWindow, or left blank
    OnDrag=
    OnClose=Exit(SKINbedder)
    [New]
    Top=338
    Bottom=390
    Left=3
    Right=120
    ;If OnPressUp and OnPressDown both have values, then the button will "toggle"
    OnPressDown=
    OnPressUp=Play(ButtonClick.wav),Focus(NSMap),Send( CTRL-N)
    [Open]
    Top=338
    Bottom=390
    Left=132
    Right=249
    OnPressDown=
    OnPressUp=Play(ButtonClick.wav),Focus(NSMap),Send( CTRL-O)
    [Scan]
    Top=338
    Bottom=390
    Left=262
    Right=379
    OnPressDown=Play(ButtonClick.wav),Focus(NSMap),Sen d(CTRL-B)
    OnPressUp=Play(ButtonClick.wav),Focus(NSMap),Send( CTRL-B)
    [Save]
    Top=338
    Bottom=390
    Left=391
    Right=507
    OnPressDown=
    OnPressUp=Play(ButtonClick.wav),Focus(NSMap),Send( CTRL-S)
    [Exit]
    Top=338
    Bottom=390
    Left=519
    Right=635
    OnPressDown=
    OnPressUp=Play(ButtonClick.wav),Focus(NSMap),Send( ALT-F4)
    ;Text can be overlaid in the center of the Rect.
    Font=
    Size=
    Style=
    Text=
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Feb 2004
    PA, USA
    And here's a screen capture.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Nov 2004
    L.A.
    I'm not sure why clicking on the skin would help it work, but I would tweak your startup script a bit...
    You had:
    Code:
    You don't need to focus on NS, and I'd add a delay after running the EXE:
    Code:
    StartUp=Run(C:\Progra~1\Networ~1\Netstumbler.exe),Wait(1000),Embed(NSMap:500),LoadSkin(NSMap:Skin)
    The reason you want to wait is that the embed() command will sometimes get the WindowHandle and try to embed the window before the application has even shown the window on the screen. This causes all the width/height math to get all messed up and it doesn't embed properly.
    I plan to fix this in a future version by checking for the window to be visable before trying to embed it.
    Feb 2004
    PA, USA
    Still doesn't work. And now, it doesn't work, even if I click on the skin before NS launches. I tried fiddling with the numbers, but no doing.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Nov 2004
    L.A.
    Ok... I remember now. The problem is that NS has a random number as part of the title. Sb does not support partial matches. If you search you may find a few solutions that have been done in the past. However, I just actually installed NS for the first time and I came up with a quick solution that will probably work best...
    Here is my start-up:
    Code:
    StartUp=Run(C:\Progra~1\Networ~1\Netstumbler.exe),Wait(3000),Send(Ctrl-F4),Embed(NSMap:500),LoadSkin(NSMap:Skin)
    The Ctrl-F4 will close the sub-window which will cause NS to remove the numbers from its title. Then Sb can embed it. After the Embed() command, you could also send an Ctrl-N to open a new window back up.
    Feb 2004
    PA, USA
    Alright, I got it to work. I used the script that is in the folder (startup.exe) to launch it, and open the appropriate ns1 file. Then skinbedder takes over again, and finishes the skinning. Here'e the resulting stuff.
    Code:
    StartUp=Run(C:\Progra~1\Skinbe~1\Netstu~1\startup.exe),wait(500),Embed(NSMap:500),LoadSkin(NSMap:Skin)
    The AutoIt script:
    Code:
    Run("C:\Program Files\Network Stumbler\NetStumbler.exe myns1.ns1", "C:\Program Files\Network Stumbler\", @SW_MAXIMIZE)
    WinWaitActive("Network Stumbler - myns1.ns1","",1000)
    Now the problem is that the buttons still don't work!
    Could it be that I have them defined in the wrong spot? And if so, do I define them by the loaction in pixels on the skin? Or what?
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Feb 2004
    PA, USA
    Bump.
    My buttons still don't work. I've changed the numbers, but nothing is happening. Am I defining them wrong? I tried clicking on anywhere on the skin, but still nothing.
    Here's what I have.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    the buttons coordinates are relative to the bitmap, not to the sb window.
    just replace on skin.ini
    Top=338
    Bottom=390
    with
    Top=3
    Bottom=55
    and they will work
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Nov 2004
    L.A.
    Sorry I missed your post on the 13th. Thanks for the bump .
    Bravellir is correct. If you have any other problems please post back and I will try to help. Also, please post your SKIN in a new thread once complete and you are happy with it.
    One concern: Why do you have to use an Auto-It script? The WinWaitActive command in the AutoIt script doesn't even do anything since your SKINbedder script is Run() instead of RunWait(). Try just running NS instead of the AutoIt script and I bet it will work.
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 02:51 AM
  2. Roadrunner Skinning Tutorial
    By Meelobee in forum RR Skins
    Last Post: 12-30-2005, 08:28 PM
  3. Thoughts on skin design guidelines?
    By Arathranar in forum RR Skins
    Last Post: 06-13-2005, 06:54 PM
  4. Frodoplayer 1.0.9 Skin Released
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 02-13-2005, 11:38 PM
  5. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 10:50 PM
