Sorry civ, I have little to no experiance with RR. Hopfully someone else will chime in.
Printable View
A new version has been posted that uses the "nowarning" command line parameter via auto-it script instead of embedding the nag and sending it enter.
Nevermind!
uh, wherte can I get this "older" skin? I am using 1.6,. and I am going out of my mind with the constant focus change and stuff. I have a big road rally race coming up in just three weeks, and I am depending on this gps software to get us there.Quote:
Originally Posted by RPM_VR4
www.baberally.com
Download SbV3 - Preview 1. It comes with the original iG skin. Preview 2 came with a GooPs skin instead. I never posted the original iG skin as a thread in the skins forum because it still needs a lot of work.
You still get focus changes with the older skin as well, just not as much in my experiance. Although, sometimes I can use the new one without focus changes as well now??? Anyway, the only solution to your problem is to not use CF 1.6.
I think I have it working pretty well now. I am using the jit big butts patch, and nothing else. the focus still changes when I bring up an options box, but if I just click on the center of the CF screen it brings the IG page back up.Quote:
what I want to know is, is there any way to get rid of the grossly oversized and pointless bar in the top of that screen?
what I mean is the nearly 1 inch tall band accross the top of the IG window,. with the skinbender iguindance caption and the OSK button, the fullscreen button,. and the X in this picture below...
http://www.mp3car.com/vbulletin/atta...1&d=1145947262
of course, I am sure you are all going to tell me that that is a CF issue and to take it up with veetid.
The full-screen bar is a lot smaller (click the middle button in the upper right). Also, you can do whatever you want by editing the CF skin.
I'm lost, can someone explain how to use this? I have iG 2.1.3, and all I knew how to do was copy the bbig.zip files over to my iG folder and run the "run-iG.exe" or whatever. The only thing it did was knock out the nag screen, I didn't get big buttons and it's not integrating in CF. Do I need to use skinbedder or something? I'm confused.
-Brian
Um... you need to do a lot more reading :)
Post number 6 has a link to the Big-Button mod. That is totally separate from this Sb skin. Unfortunately since you have 2.1.3 you are SOL because the BB-Mod won't work with it.
As for the buttons on the bottom, removing the window boarders and menu bar, and getting rid of the nag... yes, you need to install SKINbedder. This is a skin for SKINbedder that makes it embed iGuidance. You were not supposed to copy anything to the iG folder.
Ok... I've been using IGmod but thought that this mght be worth a try since it looked pretty nice...
I have downloaded and installed the newest version of Skinbedder, unzipped that one and then unzipped this one into that folder... edited the skinbedder ini vile to point to this one instead of the google thingy but the problem I have that I'm running IG for europe...
tried going into the skin folder and editing the launch path but since it's C:\Program\Inav\Iguidance Europe\Iguidance.exe it seems to have some problem with the spacing in that path... when I try and run Skinbedder all I get is:
"Run Error: c:\program\iguidanc not found!"
I tried the old DOS path and changed Iguidance Europe to Iguidance~1 instead but that didnt work either... still the same error...
