Results 11 to 20 of 23
Thread: New iGuidance SKIN!!!
  1. #11
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Sorry civ, I have little to no experiance with RR. Hopfully someone else will chime in.
  2. #12
    Nov 2004
    L.A.
    A new version has been posted that uses the "nowarning" command line parameter via auto-it script instead of embedding the nag and sending it enter.
  3. #13
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    Nevermind!
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
  4. #14
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    Quote Originally Posted by RPM_VR4
    Awesome. Please do. The ultimate iG skin would definatly be to do everything with reshacker that you can, and do the stuff you can't using SKINbedder or iGMod.
    BTW: This skin doesn't work very well with CF1.6 because of the focus issue. The older iG SKIN does work with CF1.6 fairly well because it embeds all sub-windows to the main-app. CF only switches to main if it detects a sub-window having focus. Since the old SKIN embedded all sub-windows, CF switched back to main a lot less often. This SKIN will be awesome with 1.7 though.
    uh, wherte can I get this "older" skin? I am using 1.6,. and I am going out of my mind with the constant focus change and stuff. I have a big road rally race coming up in just three weeks, and I am depending on this gps software to get us there.
    www.baberally.com
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  5. #15
    Nov 2004
    L.A.
    Download SbV3 - Preview 1. It comes with the original iG skin. Preview 2 came with a GooPs skin instead. I never posted the original iG skin as a thread in the skins forum because it still needs a lot of work.
    You still get focus changes with the older skin as well, just not as much in my experiance. Although, sometimes I can use the new one without focus changes as well now??? Anyway, the only solution to your problem is to not use CF 1.6.
  6. #16
    Aug 2005
    Lewiston, Maine
    I think I have it working pretty well now. I am using the jit big butts patch, and nothing else. the focus still changes when I bring up an options box, but if I just click on the center of the CF screen it brings the IG page back up.
    what I want to know is, is there any way to get rid of the grossly oversized and pointless bar in the top of that screen?
    what I mean is the nearly 1 inch tall band accross the top of the IG window,. with the skinbender iguindance caption and the OSK button, the fullscreen button,. and the X in this picture below...
    of course, I am sure you are all going to tell me that that is a CF issue and to take it up with veetid.
    .______
  7. #17
    Nov 2004
    L.A.
    The full-screen bar is a lot smaller (click the middle button in the upper right). Also, you can do whatever you want by editing the CF skin.
  8. #18
    Dec 2005
    Santa Barbara, CA
    I'm lost, can someone explain how to use this? I have iG 2.1.3, and all I knew how to do was copy the bbig.zip files over to my iG folder and run the "run-iG.exe" or whatever. The only thing it did was knock out the nag screen, I didn't get big buttons and it's not integrating in CF. Do I need to use skinbedder or something? I'm confused.
    -Brian
  9. #19
    Nov 2004
    L.A.
    Um... you need to do a lot more reading
    Post number 6 has a link to the Big-Button mod. That is totally separate from this Sb skin. Unfortunately since you have 2.1.3 you are SOL because the BB-Mod won't work with it.
    As for the buttons on the bottom, removing the window boarders and menu bar, and getting rid of the nag... yes, you need to install SKINbedder. This is a skin for SKINbedder that makes it embed iGuidance. You were not supposed to copy anything to the iG folder.
  10. #20
    Mar 2005
    Sweden/Vaxjo
    Ok... I've been using IGmod but thought that this mght be worth a try since it looked pretty nice...
    I have downloaded and installed the newest version of Skinbedder, unzipped that one and then unzipped this one into that folder... edited the skinbedder ini vile to point to this one instead of the google thingy but the problem I have that I'm running IG for europe...
    tried going into the skin folder and editing the launch path but since it's C:\Program\Inav\Iguidance Europe\Iguidance.exe it seems to have some problem with the spacing in that path... when I try and run Skinbedder all I get is:
    "Run Error: c:\program\iguidanc not found!"
    I tried the old DOS path and changed Iguidance Europe to Iguidance~1 instead but that didnt work either... still the same error...
    Swedish site for CarPC's
    http://www.bilpc.info
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 05:26 AM
  2. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 12:41 PM
  3. Some type of memory bug with Skin?
    By civic5zigen in forum Road Runner
    Last Post: 10-30-2005, 07:39 PM
  4. YASQ: Skin Paths not correct
    By Viscouse in forum Road Runner
    Last Post: 09-24-2005, 08:14 AM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 09:13 PM
