Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: New iGuidance SKIN!!!
  1. #21
    Banned RPM_VR4's Avatar
    Nov 2004
    Yes, it doesn't like the space. The old DOS path should have worked but you have to make sure it is correct (for example if you ever installed USA first then the europe install would be ~2 not ~1).
    Anyway, none of this matters because you need to run it with the -nowarning flag and you can't do that via Sb. This is why my SKIN does not run iGuidance at all. Instead it runs Run-iG.exe (an AutoIt script) which is in the skin folder.
    1) Restore the ini file so it runs Run-iG.exe as it did before.
    2) Instead of editing the ini file, edit "Run-iG.au3".
    3) Install AutoIt, then right click the .au3 and click compile to make it into an .exe.
  2. #22
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    Quote Originally Posted by RPM_VR4 View Post
    you can type or send keys)
    I installed v3r2 and the TYPE command doesn't work, if I use SEND then it works fine though
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  3. #23
    Nov 2004
    Try downloading it again. If you have the V3-P2 of SKINbedder.exe then the TYPE() command works. The SEND() command still works too though (but the type command does it a new "better" way needed for Google Earth compatibility). The Google Earth skin that comes in the RAR with SbV3-P2 uses the TYPE() command.
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 01:41 PM
  3. Some type of memory bug with Skin?
    By civic5zigen in forum Road Runner
    Last Post: 10-30-2005, 08:39 PM
  4. YASQ: Skin Paths not correct
    By Viscouse in forum Road Runner
    Last Post: 09-24-2005, 09:14 AM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 10:13 PM
