Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: New iGuidance SKIN!!!
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Ok, after using JIT's "Big-Button" modification, the need to embed every iG window is greatly reduced. I have just created a stripped down iG SKIN for use with JIT's Big-Button patched EXE.
    I would still like to do a full skin for iG with everything embedded, alpha-blends working properly, and iGZoom integrated. This is a long way away though. For now, I think this works pretty damn well.
    Attached Files Attached Files
    Nov 2004
    L.A.
    More Screen-Shots.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    Looks good.
    I've meant to say this earlier, but good work on Sb v3 preview 2. I like it alot and am integrating it into my system. When I finish my skin for iG, I'll post it.
    -psyrex
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
    Nov 2004
    L.A.
    Awesome. Please do. The ultimate iG skin would definatly be to do everything with reshacker that you can, and do the stuff you can't using SKINbedder or iGMod.
    BTW: This skin doesn't work very well with CF1.6 because of the focus issue. The older iG SKIN does work with CF1.6 fairly well because it embeds all sub-windows to the main-app. CF only switches to main if it detects a sub-window having focus. Since the old SKIN embedded all sub-windows, CF switched back to main a lot less often. This SKIN will be awesome with 1.7 though.
    Maximum Bitrate Civic03's Avatar
    Dec 2005
    RPM where can I find the JIT's "Big-Button"? I searched but it only brought me to this post.
    PROGRESS 95%[//////////]Complete - Software configurations
    Current Task: Just adding on...
    Needed:wireless keyboard/mouse
    My Carputer Blog
    Car System Site
    FLAC PURDooM's Avatar
    Jun 2005
    Anoka County, MN
    Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
    Unlimited Internet and gps tracking for $6 a month with boost mobile!
    Carputer 2: www.lmaocar.com
    Dec 2005
    Thanks guys I stumbled on it too and it turned out I already had it!!
    My Carputer Blog
    Car System Site
    Jan 2004
    NYC
    RPM - does the skinbedder OSK work with IG?
    Nov 2004
    L.A.
    There is no "SKINbedder OSK". You can make an OSK with Sb and I have done so only for the older iG SKIN (so yes, the older iG SKIN has a custom OSK). This new iG skin is only one set of buttons.
    It is hard to make an Sb SKIN with a different botton set for each sub-window, because the sub-windows can change or be closed in responce to button presses on the sub-window and keyboard commands. This gets Sb lost because it only knows when you click one if its buttons. This is why the old iG SKIN is "buggy".
    Until I have time to do some more development on SbV3 final, Sb really only works perfect if you just have one button overlay set and you use non-alphablended PNGs.
    The "Sb-OSK" as you put it is only capable of sending keys to a specific embedded window. It is not like the Windows OSK that automatically sends the keys to which ever window had focus before you touched the Windows OSK (see, when you click an Sb button, Sb takes focus away from the embedded app, which is why the first line of any button command needs to be focus([window-name]) and then you can type or send keys)
    Dec 2005
    Which skin have you guys been able to use with this. I can run SkinBedder by itself and it works but some skins do not work like Xeon, LSX etc. Just wondering if it is working with some known skins and how you were able to get it to work. I can get the layout to show in some but IG itself doesn't wrap with the BBiG.
    My Carputer Blog
    Car System Site
  1. MMI eXtnd
    By proTONEd in forum FP Skins
    Last Post: 04-17-2008, 06:26 AM
  2. Red highlights for BMV2 Skin done
    By Mad Ad in forum RR Skins
    Last Post: 10-17-2006, 01:41 PM
  3. Some type of memory bug with Skin?
    By civic5zigen in forum Road Runner
    Last Post: 10-30-2005, 08:39 PM
  4. YASQ: Skin Paths not correct
    By Viscouse in forum Road Runner
    Last Post: 09-24-2005, 09:14 AM
  5. finnaly skin uploaded
    By liquid_smoke in forum ME Archive
    Last Post: 12-31-2003, 10:13 PM
