Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 39
Thread: RELEASE: iGuidance 3.0 UMPC Skin
  1. #11
    Raw Wave
    Jun 2002
    Virginia
    Thanks for the nice skin, RPM.
    I have no previous experience with SKINbedder so am trying to muddle my way through making the skin work with the CFX skin in RR. I've been able to get it to successfully embed by changing the form positions in iG3.ini. The only issue I'm having is that SKINbedder doesn't close when I exit RR so I have to go in and manually close it in order for the nav screen to disappear. I'm just wondering what I have to do to get SKINbedder to close with RR. Sorry if this is a noob question.
    b8bboi, I like your idea of the hideable buttons. That was a nice feature of IGMon.
  2. #12
    Raw Wave
    Jun 2002
    Virginia
    Nevermind my previous question about closing Skinbedder on RR exit. I set it up in my car and it's a non-issue.
    For me, it looks like IG3 with RPM's skin and b8bboi's IGmon is the final nav solution. Everything works beautifully together. The only additional features that could possibly improve the current setup is hideable buttons on RPM's skin and a functional next turn box in IGMon.
    For anyone who's interested here are the form position settings I used in IG3.ini in RPM's skin to get IG3 to properly embed in b8bboi's blue 800x600 CFX skin:
    ;This is the initail position of the form.
    Top=90
    Left=141
    ;This is the initial "usable" Width & Height of the form.
    ClientWidth=650
    ClientHeight=420
  3. #13
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by Anointed
    Does skinbedder allow my GPS to reconnect after hibernation? Is there something I need to do to set the commport?
    I haven't had any trouble with GPS connect after hibernation while using this skin without special settings.
  4. #14
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    My skin has hideable buttons.
    Get it here.
    Any tips for using SB/iG3 with iGMon? Is there anything I need to disable?
  5. #15
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by ITL
    Looks good. I'll check it out.
    I disabled everything in IGMon.ini except auto switching to GPS screen, which is the IGMon feature that I really wanted. I also manually removed the couple of buttons that IGMon creates. If you're using SKINbedder, you need to make sure to change the IGuidance window name to "SKINbedder - iGuidance" in IGMon.ini. Other than those changes, I didn't do anything.
  6. #16
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    sweet...that's exactly wht I need
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  7. #17
    Raw Wave
    Jun 2002
    Virginia
    ITL, I assumed you'd know how to remove the IGMon buttons because you're a pro at this stuff, but just in case, here's how to do it:
    Quote Originally Posted by b8bboi
    Open OnScreenButton.ini and comment out all the buttons by placing a ; on each line. Like this.
    Code:
    ;This is an exmple of buttons with images
    ;PLEASE USE BMP as support for GIF and JPG is pretty crappy
    ;ShowButton = 0, -150, 80, 50, 160, 1, "ShowHideButtons", "osd.bmp", "osd_on.bmp"
    ;MenuButton = 0, -60, 80, 60, 255, 1, "iGMenu", "menubutton.bmp", "menubutton_on.bmp"
    ;ToggleAutoZoom = -81, -115, 80, 50, 160, 0, "ToggleAutoZoom", "autozoom.bmp", "autozoom_on.bmp"
    ;Toggle3d1_2d = -81, -170, 80, 50, 160, 0, "Toggle3D2D", "3d2d.bmp", "3d2d_on.bmp"
    ;CancelRoute = -81, -225, 80, 50, 160, 0, "CancelRoute", "cancel_route.bmp", "cancel_route_on.bmp"
    ;POIs = -81, -280, 80, 50, 160, 0, "ToggleCustomPOIs", "pois.bmp", "pois_on.bmp"
    ;GoHome = -81, -280, 80, 50, 160, 0, "GoHome", "gohome.bmp", "gohome_on.bmp"
  8. #18
    Dec 2005
    Tampa, FL
    How would I go about embedding this into CF 1.7 ?
    thanks
    Tony
    Hardware: VIA-SP13000, M2-ATX, Voom case, HQCT, Linksys WiFi, Bluetooth, 512MB, 80GB, Dynamix 706.
    Software: XP Pro (stripped), Drivers only, Road Runner, CentriFuse, EzSync
    99% done... [never completely finished... a continuing hobby]
  9. #19
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Add an app to CF 1.7 as follows...
    Name: Whatever you want
    Command: SKINbedder.exe
    Parameters: iG3
    Window Title: SKINbedder - iG3
  10. #20
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by kbreeden
    thanks for the tip...always better to know exactly where to go before you get there I'll just comment out those lines, update the window title, and disable anything other than auto-switching.
    500+ full albums
    4,000+ video games
    old carPC
  1. AutoRoute Skin for Alpine
    By Salveeno in forum Road Runner
    Last Post: 05-25-2006, 09:31 AM
  2. Flash RR Skin Beta Release
    By CdRsKuLL in forum RR Skins
    Last Post: 01-15-2006, 08:48 PM
  3. FRODOPLAYER 1.0.9 SKIN in progess
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-27-2004, 10:07 AM
  4. FrodoPlayer SkinMaker Alpha Release
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-03-2003, 10:36 PM
