Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: PREVIEW: iGuidance 3 skin
  1. #11
    Raw Wave
    Jun 2002
    Virginia
    Quote Originally Posted by kjones2k1
    I have this same problem, but I did this to fix it:
    1. Go to \SKINbedder\iG3\iGMap
    2. Open iGMap.ini
    3. Find the code "NudgeDown=20"
    4. Change the value to fit your screen. I changed mine to '2' and it fits perfectly, both running SKINbedder outside RR and inside RR.
    I changed mine to 2 also and it works great. Thanks.
  2. #12
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Quote Originally Posted by ITL
    It works just fine. They are "anchored" from the bottom left, so to speak. I changed the res for the skin and it looks okay.
    It looks to me like you should have 2 inis. One ancored to the bottom left and one ancored to the bottom right. That way if the horizontal res is change, both buttons will still lineup with the correct edge of the screen.
    The way it is now, if someone used it in CF which has full 800 horizontal res, the two buttons on the right side would be closer to the middle of the map and not against the side any more.
    EDIT: Wait a minuite... your screen-shots have full 800 res too. I don't understand how that is possible with one PNG pair and one INI? Did the CFX skin people have to edit the PNG? EDIT2: Nevermind, I see you do have lots of inis. You just consolidated some of them into one, not all of them in to one. Nothing to see here... move along.
  3. #13
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    2. Open iGMap.ini
    awesome, I completely forgot about the nudge value. I did remember having this problem before, but forgot how I fixed it. Thank you!
    Quote Originally Posted by RPM_VR4
    Yes, only the hidden buttons were consolidated. I actually need to revise the skin. On my 800x600 res, when I use the left and right arrows, the right arrow becomes hidden and unusable. I may move it either to the left edge or over to the right somewhere. Expect another version this week.
    Also, would anyone care for larger buttons? This works fine for me, as I was trying to maximize the real estate for the map...I'd be glad to create another skin with larger buttons if anyone would use it...
    The only issue I have seen, and its cosmetic, not a bug, is that when you drag the map, the iG menu button drops down creating two menu buttons. Not really a problem, but the duplication kinda bugs me. Check it out and let me know if you have any ideas...
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  4. #14
    Nov 2004
    L.A.
    My skin doesn't work well on a 800x480 screen and the UMPC version. I think I may do what JIT did and make a skin for the non-UMPC version. UMPC works great on my 8.9" Tablet PC at 1024x600, but it is a little too big for 7" if you ask me.
  5. #15
    Jul 2006
    Is anyone having a problem with GPS receiver reconnecting after hibernation? Mine does not connect after hibernation. Is there some coding I need to put into the IG.ini file? I'm using a BU-353 and iGuidance 3.0.
  6. #16
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Sorry, bro, I don't hibernate. I think you can set some sort of delay. I think there might be another solution that tricks the GPS into thinking it's receiving data until it actually does...GPSSecure maybe? Not sure if that's it, but I believe your solution is here on the forum.
    500+ full albums
    4,000+ video games
    old carPC
  7. #17
    Nov 2004
    L.A.
    The iGLaunch solution was to change iG's comport on hibernation then change back on resume. You can script that using SKINbedders OnHibernate and OnResume scripts. I posted about that recently. Do a search.
  8. #18
    Jul 2006
    Do you have a skin with the standard 'Menu" button on the left only and on the right you have the '3D' and 'Save' button?
  9. #19
    Nov 2004
    L.A.
    Download this skin. Open iG3\iG3.ini. Find the [Script] section and delete LoadSKIN(iGMap:Menu) and LoadSKIN(iGMap:Show) from the startup=script
    Code:
    Change:
    [Scripts]
    ;This is the startup script that tells SKINbedder what to run, embed, and skin with.
    StartUp=RunWait(Run-iG.exe),Wait(100),Embed(iGMap:5000),Wait(100),LoadSkin(iGMap:Menu),LoadSkin(iGMap:Show),LoadSkin(iGMap:ThreeD),LoadSkin(iGMap:Save)
    To:
    [Scripts]
    StartUp=RunWait(Run-iG.exe),Wait(100),Embed(iGMap:5000),Wait(100),LoadSkin(iGMap:ThreeD),LoadSkin(iGMap:Save)
  10. #20
    Raw Wave
    Jun 2002
    Virginia
    I have no problem with reconnecting after hibernation and am using the same receiver and program as you. I have no special settings to make this work. Make sure your receiver is plugged into a USB slot on the computer rather than on a hub.
  1. Replies: 570
    Last Post: 11-05-2009, 02:49 PM
  2. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 11:42 AM
  3. Simple Skin Preview
    By arise360 in forum FrodoPlayer
    Last Post: 01-03-2005, 10:35 PM
  4. VERY Early Preview of a skin
    By bimmercore in forum MediaCar
    Last Post: 09-18-2004, 05:17 AM
  5. skin preview
    By liquid_smoke in forum ME Archive
    Last Post: 12-16-2003, 08:48 PM
