Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
Thread: PREVIEW: iGuidance 3 skin
  1. #21
    Jun 2002
    Virginia
    ITL, you've spotted the only two improvements that the skin could use as far as I'm concerned. First, as you pointed out, the location of the left and right arrows is not ideal because the windows that appear obscure them and they become useless. Second, the buttons at the bottom corners should be a little bigger. I know you were trying to save real estate, but I do find myself fumbling around with them at the current size. I would definitely like to see those changes.
    By the way, I assume the "3" button is supposed to toggle between 2d and 3d view. Is that correct? For some reason I get no response of any sort when I tap it.
  2. #22
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by kbreeden
    I will definitely be moving the right arrow, and probably the left, too. Is the left arrow hidden from you when in use? Only the right is hidden for me.
    The buttons at the bottom corners are a pain for me, too. I have too spend too much time "focusing" on the screen to make sure I hit the right one. I will make them bigger.
    The 3D/N button sends two commands. I typically like to have my heading up, with the 3D view. However, anytime I switch to the bird's eye view, I like to have North up for frame of reference- so my skin sends both commands...easily editable in the .ini file. Try clicking on the map to ensure that iG has focus...other than that I'm not really sure why it wouldn't work for you.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  3. #23
    Jun 2002
    Virginia
    Yes, on my 7" TS with the CFX skin at 800x600 both the left and right buttons are obscured.
    I'm wondering whether you could even get by with just one of the buttons since there are only a couple of screens to scroll through. You would just be able to scroll in one direction.
  4. #24
    Jul 2006
    Quote Originally Posted by RPM_VR4
    Download this skin. Open iG3\iG3.ini. Find the [Script] section and delete LoadSKIN(iGMap:Menu) and LoadSKIN(iGMap:Show) from the startup=script
    Code:
    Change:
    [Scripts]
    ;This is the startup script that tells SKINbedder what to run, embed, and skin with.
    StartUp=RunWait(Run-iG.exe),Wait(100),Embed(iGMap:5000),Wait(100),LoadSkin(iGMap:Menu),LoadSkin(iGMap:Show),LoadSkin(iGMap:ThreeD),LoadSkin(iGMap:Save)
    To:
    [Scripts]
    StartUp=RunWait(Run-iG.exe),Wait(100),Embed(iGMap:5000),Wait(100),LoadSkin(iGMap:ThreeD),LoadSkin(iGMap:Save)
    Worked like a charm. Thanks.
    I have no problem with reconnecting after hibernation and am using the same receiver and program as you. I have no special settings to make this work. Make sure your receiver is plugged into a USB slot on the computer rather than on a hub.
    I'm not using a hub. I did some reading, my problem might be coming from not having all the windows hotfixes. However, I did fix the issue with a program called Xport3, I think thats name.
    Agreed. I tried editing the 3D and save ini file for the size, but I did not manage to see any change in size. I was probably doing some thing wrong, so I guess I'll have to wait until ITL releases a new version.
  5. #25
    Jun 2002
    Virginia
    Quote Originally Posted by kjones2k1
    However, I did fix the issue with a program called Xport3 ...
    That makes sense. Xport3 splits the commport so it can be used by two devices. Roadrunner was probably grabbing the commport and making it unavailable for your GPS receiver to use.
  6. #26
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    The Width/Height of a SKINlayer is determined by the Width/
    Height of the PNG, so it's not in the ini file. The ini file onle specifies location of the PNG and one or multiple buttons within the PNG.
  7. #27
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    I'll try to get something going this evening...
    500+ full albums
    4,000+ video games
    old carPC
  8. #28
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    deleted...
    500+ full albums
    4,000+ video games
    old carPC
  9. #29
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    new, more stable skin
    new more stable skin with better buttons:
    Attached Files Attached Files
    500+ full albums
    4,000+ video games
    old carPC
  10. #30
    Jun 2002
    Virginia
    Thanks, ITL, I can't wait to try it out.
  1. Replies: 570
    Last Post: 11-05-2009, 02:49 PM
  2. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 11:42 AM
  3. Simple Skin Preview
    By arise360 in forum FrodoPlayer
    Last Post: 01-03-2005, 10:35 PM
  4. VERY Early Preview of a skin
    By bimmercore in forum MediaCar
    Last Post: 09-18-2004, 05:17 AM
  5. skin preview
    By liquid_smoke in forum ME Archive
    Last Post: 12-16-2003, 08:48 PM
