v2 added...first post updated.
see post #29 for latest file and screenshots.
ITLs Skinbedder3 skin for iGuidance3.
Current version: ITLv4.0
CarPC #3: 99% Complete
Pentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more!
old carPC
v2.1 added...
ITLv2.1 consolidates the four hidden buttons to make the file size smaller and put 4 ini files into 1.
500+ full albums
4,000+ video games
old carPC
? Are you sure you want 4 ini files into 1?
I use 5 ini's in my skin so I know the buttons will always be the spaced correctly from the proper edge no matter what the window is resized to. The left and right side buttons are vertically centered and always on the edge, the zoom buttons are horizontally centered the proper distance from the bottom, and the other buttons are always the same distance from the lower left & right corners.
You can do it how you like, I just wanted to make sure you understand how the boarder left/right/top/bottom variables work.
It works just fine. They are "anchored" from the bottom left, so to speak. I changed the res for the skin and it looks okay.
What I meant was that I have 4 hideable buttons in the bottom left corner (think BotLeft.ini) from your skin. I wanted to make them ALL hideable, but had a separate .ini and separate .png file for each button. You can see them load one at a time, and in the order they are defined. By putting all four in one .png file, I can use one .ini file and load them at once: less code, smaller filesize, cleaner/quicker skin loading.
I made my buttons half the size of the originals. I like to maximize screen space for navigation. If anyone would like larger buttons, let me know. I run 800x600 so the current skin works well for me. Anyone runnig anything larger might fat-finger the buttons![]()
Nice skin, ITL. Here's what I'm getting, though. Things aren't lining up properly on the bottom. No sure, but this may be the issue RPM was describing above.
Your bottom is cut off...look at your mph. If you fix the embedding of iG, the buttons should line up.Originally Posted by kbreeden
500+ full albums
4,000+ video games
old carPC
What file is this exactly?? I'm having the same problem.Originally Posted by ITL
I thought I did embed properly. Is there something else I need to do besides adjusting the form size and position in ig3.ini? I tried reducing the client height but that didn't fix the problem (see attached). The same thing also happens even when I open SKINbedder outside of RR. This issue did not occur with RPM's skin.Originally Posted by ITL
I have this same problem, but I did this to fix it:Originally Posted by kbreeden
1. Go to \SKINbedder\iG3\iGMap
2. Open iGMap.ini
3. Find the code "NudgeDown=20"
4. Change the value to fit your screen. I changed mine to '2' and it fits perfectly, both running SKINbedder outside RR and inside RR.
