Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: RELEASE: GE-Nexus (for GooPs / Google Earth in CF Nexus)
  1. #21
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    Sorry Merc, the address stuff is done through RREarth. Freedom-Earth is not even a SKINbedder skin. It's just an RR skin with a bunch of Auto-It scripts that control GooPs.
    I would update GE-Nexus if I could add the addresses, but just updating to GooPs 1.8 doesn't make much sense. If you want to use 1.8, all you have to do is copy 1.8's .exe to the folder, open the main GENexus.ini file and change it kill 1.8, then edit the Run-GE.au3 auto it script and tell it to run 1.8, then right-click, compile it to Run-GE.exe.
    If you ever want to make a RR skin I would be happy to help you with ini/skin files and making iG/GE/Sling skins for it.
  2. #22
    Variable Bitrate mercury7's Avatar
    Jul 2005
    Dallas
    For some reason, Goops isn't getting skinned using 1.8. Do I need to change the window class param in the "GooPsWindow" folder?
    2002 Grand Am progress :
    [] - 80%
    ...complete setup, but still need to make the install cleaner
  3. #23
    Nov 2004
    L.A.
    I don't think so... only the filename changes, the window names have always been the same I believe. I can look at making you a GE-Nexus for 1.8 if you are having trouble with it. All you should really have to do is change the auto-it script though (???).
  4. #24
    Dec 2007
    Hello to all!
    Please explain what I need to use that google earth on my carpc. Do I have to buy CF or is demo version enough?
  1. Google Earth Cache Builder
    By njwashor in forum Other Cool Stuff
    Last Post: 07-27-2007, 10:54 AM
  2. RELEASE: iG-Nexus (for iG3 UMPC, CF, Nexus)
    By RPM_VR4 in forum SB Skins
    Last Post: 10-25-2006, 10:53 PM
  3. Google Earth: How?
    By sux89 in forum MacCar
    Last Post: 03-15-2006, 08:05 PM
  4. Google Earth SKIN (in progress)
    Last Post: 02-15-2006, 06:45 PM
  5. Embedding Google Earth to RR
    By Asskick in forum Road Runner
    Last Post: 02-10-2006, 09:44 AM
