Ok I finally got it to embed properly...but once it embeds it doesnt show the right side .png to switch 2d/3d and heading anymore...uggh
I believe the window title is "iGNexus", not "iG3".
You can change the window title to whatever you want by editing iGNexus.ini. As long as CF matches that it will embed.
? This was designed for use with JITs Nexus CF Skin at 800x480. If you look at the two top pictures in the first post of this thread, you will see that one of them has Save/Cancel on left and 3D/N on right, but the other one doesn't. This is full-screen vs. normal. In JITs Nexus skin, you have to click the very left edge to switch between full-screen or normal (there is no button, just click anywhere on the left edge). You can also setup CF to default to full-screen when you first open it through the setup iG3 options.
RPM is such a big Nexus supporter, that he knows how to use my skin better than I do LOL!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
OMFG it works now...I could have sworn that I tried "iGNexus" as a window title before but I guess not....thanks for the help RPM and Justintime. Really appreciate the work you do on these forums
2002 Honda CR-V
HI,
I'm french sorry for my very bad English,
I installed this skin for use IG3 in CF and i have a problem when i close IG3 in CF
Message error from Skinbedder during 2 sec
"Acces violation at adresse 00A13BDA. Read of adress A13BD800"
Can you help me for resolv this problem ?
Ok guys ive got some issues that are starting to affect usability. The bars on the left and right of the nav screen arent sticking to the bottom bar. So they are all scrunched up and hard to press and there is a gap where the skin should be that looks kinda bad. Any ideas on what could be causing this?
