Results 1 to 10 of 12
Thread: RELEASE: iG-Freedom
    Banned RPM_VR4's Avatar
    Nov 2004
    L.A.
    RELEASE: iG-Freedom
    I just discovered Freedom skin for RR. Here's my iG skin for it. No buttons in windowed, 5 on each side when full-screen. Buttons are stolen from Freedom skins OSK.
    Remember you must compile Run-iG.au3 using Auto-It before this will work.
    Attached Files Attached Files
    Nov 2004
    L.A.
    Update!!!
    Here's a better one (if you don't mind a smaller iG window).
    If you are using RR, you should probably just use iG-native and my RR.skin that I posted in the Freedom Skin Thread here. Then you don't even need SKINbedder at all.
    I just made this SKINbedder version for people using other FE's (but you may have to tweak the size/positions for your particular FE).
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    Yeah I did run it with IGFreedom in the default Skinbedder program location. But as for in RR i just use SKINbedder. Everything comes up but the buttons doesn't work.
    Nov 2004
    L.A.
    It works for me, but it is silly to use Sb for the side buttons in RR. Just use iGnative and my RR skin. Don't bother with Sb.
    Jun 2006
    Houston, TX
    I want to remap those keys to my skin. Anyway to do that. If i send you my skin can you remap it for me or show me. I am not using Freedom skin. I create my own personal skin for my use. Help appreciated
    Nov 2004
    L.A.
    SKINbedder skin, or RR?
    Either open up my gpsFull.skin and copy the buttons or open up iGMap.ini and copy the buttons.
    Jun 2006
    Houston, TX
    OK thanks for the buttons but how did u make the button and the IG screen disappear RESHACK?
    Nov 2004
    L.A.
    ? The button and the iG screen?
    You mean the Menu button and Mute button. Yep, reshacker. Just replace the teal square image with dot.bmp which is included in the skin.
    Jun 2006
    Houston, TX
    Quote Originally Posted by RPM_VR4 View Post
    i haven't use reshacker yet but i will play with it. The button relocation is great now my skin look custom
    Thank man
    OK i did it i reshack iguidance. Hey why dont u get ride of the menu word.
    Nov 2004
    L.A.
    I don't know how? Do you?
  1. iGMod Beta 1 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 12-28-2005, 11:17 PM
  2. [SKIN]FPs "Bright Life" (input needed to complete)
    By yunusyu in forum FrodoPlayer
    Last Post: 06-25-2005, 03:59 PM
  3. RELEASE - FreeDrive 0.60
    By CdRsKuLL in forum FreeDrive
    Last Post: 06-10-2005, 05:45 PM
  4. SpeakEasy Voice Recognition - Release 0.9.1
    By ruairi in forum Software & Software Development
    Last Post: 06-03-2005, 06:19 PM
