Screen Shot:
This actually isn't a SkinBedder skin. It is an RR skin for RREarth that matches CDrSkull's Freedom 2.1.
1) Get RREarth working (see here)
2) Unzip GooPsScripts.zip to c:\program files\Road Runner\GooPsScripts
3) With AutoItV3 installed, right-click and compile each .au3 file in to a .exe.
4) Download GooPsV1_8.exe and put it in the GooPsScripts directory.
5) Run it and configure it to work with your GPS (auto-connect, don't auto-run Google Earth).
6) Unzip other 4 skin files to skins\Freedom 2.1
Hope you like it.
FYI: I will never use this skin, any of my other Freedom skins, or CDRSkull's Freedom 2.1 skin for RR on any of EyceMobile's products or future advertising. I am just releasing my work to the community to use, modify, and redistribute however they wish.
HI RPM VR4 !
HOW I CAN USE YOUR
earth-Freedom for RREarth/GooPs/Freedom 2.1, With another SKIN ?
Easily... replayce this line:
with this line:
6) Unzip other 4 skin files to skins\{your skin of choice}
The rest is all the same. It will work fine with any skin, it just matches Freedom.
So, To get RREarth working I need to add a button to the freedom skin...how do I do that since it's a full flash skin?
2004 Nissan 350z Daytona Blue
2x 10" IDMax D4
1250.1 kicker amp
crappy dell carputer
OK !
I Unzip other 4 skin files to my skins.
WHAT CODE I need to add to button for start it ?
You guys are bypassing step #1: Get RREarth working!
The button code is "GE_START".
In Freedom 2.1, you edit menu.txt to change what all the buttons do and their icons. Just change one of them to GE_START.
I suggest you both follow step 1 and get the RREarth plugin working with the default skin first.
Okay,
I've followed the instructions and got it to work.
I was able to change the menu.txt and make it start GooPsV1_8.exe but it is although it starts in Freedom, its not using the skins that come with this plug in.
Can anyone help me out?
Okay, I missed the rrearth.zip but got that working now too.
This is really fantastic. But all I got it working in is the BMW skin.
How do I get this to work in Freedom??
Is it only in the menu.txt that I need to make a change in, or in the skin as well.
As it seems assigning a button to GE_START works different in a non flash skin.. so can anyone please tell me how I do it for Freedom?
