View Poll Results: Do you use OziEmbedded?
Voters
4. You may not vote on this poll
  • Yes
    4 100.00%
  • No
    0 0%
Page 12 of 14 FirstFirst ... 234567891011121314 LastLast
Results 111 to 120 of 132
Thread: OziExplorer
  1. #111
    Jul 2006
    Brisbane, Australia
    The RR buttons are all circular. I think you will find that the physical size of your screen is 800x480 pixels but you are running it in 800 x 600 mode. That's how mine is. So when your monitor displays graphics, they are slightly distorted becasue the monitor downscales one axis from 600 pixels to 480 pixles and circles become ovals. I just made an oval bluetooth button and when displayed in my car it is almost circular because of the same reason.
    In our Skinbedder buttons, I copied the circular buttons from the RR skins so the size and dimensions are identical. The reason the Skinbedder buttons don't go all the way to the bottom of the screen is that we deliberately designed the buttons to fit on a 480 pixel deep screen without any modification. Your monitor therefore does not need to rescale the buttons and they display correctly so circles are circles.
    If you are really annoyed by this, you can download the photoshop PSD's of the BMV2 skin and make them 800 x 480 for your monitor. The ones I found and used were 640x480 but had obviously just been resized from 800 x 600 because the buttons were oval and rescaling to 800x600 made them round again. You would need to redefine every button, label etc in every skin to that size. That would be quite a big job!
    You will be on your own from here on guys becasue I am off on a holiday overseas in New Zealand for 3 weeks in the morning!
    Rod
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  2. #112
    Newbie IceFyre's Avatar
    Oct 2006
  3. #113
    Jun 2005
    Crazyburn, Melbourne, Vic, Australia
    Hi guys/girls
    I just put a poll on this thread to get a count of how may people are using OziEmbedded... I'm interested to see how many people we are supporting with this work
    '89 GQ Patrol
    TD42 (go the Diesel!) NEW: Now with DTS Turbo - woot!!!
    "It's times like these you go BUGGER!!!"
  4. #114
    Sep 2008
    UFA
    I think, that it not may need who travel on autobahn. For this purpose there are wonderful vectorial maps. But there are many deaf corners on our planet, where it is possible to use the only scanned map of locality.
    We have for sale many navigators with the original vectorial maps (as a locomotive with the own rails), but all of them engulf cities Moscow and Sankt Petersburg and federal routes. I very like to accomplish OFF ROAD on our beautiful and wild places of nature of Ural
    Therefore by the primary purpose of the use for PCCAR for me there was GPS navigation. And here a main violin belongs Oziexplorer. I think there are many people – hunters, fishermen, and other nature-lovers which will be thankful you Oziembedded...
  5. #115
    Sep 2008
    UFA
    Your program works only partly for me. At pressure of the buttons of 6a...6e a menu appears with the square window of map. The window of RUN ERROR appears at pressure of the button «OPEN»....
    For you apparently set yet and Skinbedderv3p2 therefore part of the program works through him. Make attempt him temporally to hide elsewhere. Button F2...F6 work correctly. Button Zoom (with magnifying glass) does not work, in also time of the button RR (from above) «+» and «-» work.
  6. #116
    Jun 2005
    Oohhh... there's a bug we didn't find after moving the install location...
    in Map1.ini in the folder C:\OziEmbeddedV1.0\Ozi\Map
    change the line
    OnPressUp=Play(ButtonClick.wav),Run(C:\SkinbedderV 3P2\Ozi\Map\pressOpen.exe),Wait(1000),Close(Map),H ideSkin(Map1),LoadSkin(OziWindow:Menu1)
    to
    OnPressUp=Play(ButtonClick.wav),Run(C:\OziEmbedded V1.0\Ozi\Map\pressOpen.exe),Wait(1000),Close(Map), HideSkin(Map1),LoadSkin(OziWindow:Menu1)
    Note: there are no spaces anywhere in those lines.
    For anyone else downloading the skin, this has been fixed now.
    '89 GQ Patrol
  7. #117
    Sep 2008
    UFA
    I All the same advise to withdraw Skinbedderv3p2 from a folder and check up work of the programs from the beginning.
  8. #118
    Sep 2008
    UFA
    I probably will have to put the English version OziExplorer
    In your program the search of windows goes on the English title.
    Bat for me part of windows is had the Russian name
    >>>> Window <<<<
    Title: Поиск карт по координатам
    Class: TfmEditPosition
    Position: 101, 210
    Style: 0x16C80000
    ExStyle: 0x00000180
    Handle: 0x001705BA
    >>>> Control <<<<
    Class: TBitBtn
    Instance: 2
    ClassnameNN: TBitBtn2
    Advanced (Class): [CLASS:TBitBtn; INSTANCE:2]
    Text: Найти карту
    Position: 326, 40
    >>>> Window <<<<
    Title: Региональная карта - Мой.ozp
    Class: TfmProjectManager
    Position: 209, 101
    Style: 0x16CC0000
    ExStyle: 0x00000180
    Handle: 0x001005BC
    >>>> Control <<<<
    Class: TElTreeView
    Instance: 1
    ClassnameNN: TElTreeView1
    Advanced (Class): [CLASS:TElTreeView; INSTANCE:1]
    Text:
    Position: 2, 52
  9. #119
    Jun 2005
    @ SSan
    If I'm not mistaken, that is the pressOpen script. That and the startup script are currently the only ones which use the name as part of the script.
    In the startup script it is this line:
    WinWaitActive("OziExplorer")
    If you replace the name text in these two scripts, you should be fine.
    '89 GQ Patrol
  10. #120
    Jun 2005
    Hi All
    From the poll question I put up a while ago, we have 5 people following this thread and actually using OziEmbedded. I was hopefull that there may have been more.
    Anyway, development will continue as Rod and I am working on it to make our own systems better and we will continue to release versions as they come about.
    '89 GQ Patrol
  1. Replies: 12
    Last Post: 08-26-2008, 07:37 AM
  2. Oziexplorer
    By Subsonic in forum SkinBedder
    Last Post: 07-22-2008, 04:41 AM
  3. oziexplorer maps for offroad use
    By mjak in forum Centrafuse
    Last Post: 01-18-2007, 11:32 PM
  4. Mapsource and oziexplorer
    By reactbob in forum GPS
    Last Post: 05-14-2005, 09:09 PM
  5. Replies: 0
    Last Post: 01-05-2004, 04:04 AM
