I have another menu which is a single button to expand the menu down again... ie up button for hide and down button for show
I can make the buttons transparent using skinbedder I think... it doesn't have the same effect though. I intended to be able to minimise the menu to give more visible map space. Expand it back out when you want to use the menu. Something like that... From my experience using Ozi in the vehice, once the map is running and you have zoomed to a lever, you tend to leave it running and just want to see as much as possible of the map.
LinkBack URL
About LinkBacks
