Results 1 to 6 of 6
Thread: 325i BMW / Newbie's first project
    Apr 2007
    Sup my name is Joseph and i'm starting my first carputer project. I just started this so i would learn more about the installation process...
    Right now the system i've chosen is as follows:
    Touch Screen either in dash or motorized
    mobo:either a mini itx or possibly a nano itx
    Case: not sure suggestions would be great
    Memory: maximum for Mobo
    PSU: HELP this is my biggest question how did you hook up you carputer to your car's power
    Max harddrive supported...and a dvd burner or a just a dvd reader/cdwriter....i got to go but i will finish this post in i don't know 5 hours
    Peace...JOE
    Mar 2006
    Colorado, but Canadian!
    Case: YOu have many options. Look in the store under "enclosures" and you will see the Ampie/VoomPC, VoomPC2, and Morex cases. The first 2 only take the M1/M2 and the last one only takes the Opus.
    Also look in the FAQ section for the thread on how to power you computer from a dc-dc power supply. It explains it really well. If you have questions after reading that, then go ahead and ask.
    For the dvd burner go slim (laptop drive) because the standard 5.25" drives draw a ton of power, and it is just a waste.
    Maximum HD space... There is no maximum! The via boards have 1-2 IDE channels so 3HD's and an optical drive. Then there is USB, so up to 128 hard drives there per usb root which would be 2 root hubs per mobo. Then PCI, and you can get controllers for that to get like 8 channels, for 16 drives. So that is a couple hundred hard drives.
    But seriously, you can use a 3.5" drive which go up to 750Gb as of now for a single drive, and 2.5" which are just around 200Gb limit.
    Keep in mind if you use the Ampie/VoomPC case, you are required to use 2.5" drives and you can have up to 2. And a limited number of 44pin to 40pin IDE adapters will fit in the case.
    Each case has limitations, and benefits.
    Oh, and
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2007
    thanks for the reply
    Well....now that i have the power issue taken care of...thanks to those who wrote the FAQ does anyone know how the wiring works in the bmw...i'm trying to get an internship/job at a custom car place but any sug. before i do that?
    Variable Bitrate nitropwd's Avatar
    Sep 2003
    bloomington,mn / moss point,ms
    just research as much as possible, you dont want to spend cash on equipment you really dont need.
    ...Also can this be moved to the Newbie forum?
    Motherboard: Epox MATX
    Power: M2-ATX
    Storage: 120gb 3.5"
    Optical: Slim Slot cdrw/dvd
    Audio: SB Audigy 2
    GPS: BU-353 & iGuidance 4
    OS: Win FLP (Fundamentals)
    Frontend: Roadrunner (DFX 3 & 4)
    Apr 2007
    yeah sure.....sry....i intended to show my finished project here....sry again..
    PEace...JOE
    Variable Bitrate polo6979's Avatar
    Aug 2006
    Atlanta, GA
    PLEASE PLEASE please..... dont put a motorized monitor in your BMW. Take a look at my project if you need some ideas and shoot me a PM if you have any questions.
    2003 E46 BMW
    Lilliput Transflective, GM965 mobo w/ Processor
    ELMSCAN 5 USB, Slot load DVD, BU-353 GPS
    Everything is for sale.
  1. 03 BMW 325i install
    By Nico3k in forum Show off your project
    Last Post: 02-16-2009, 03:09 PM
  2. Project BMW E46
    By zaid175 in forum Newbie
    Last Post: 03-09-2007, 10:04 AM
  3. A Start Community Project
    By BenjaminS in forum MacCar
    Last Post: 03-25-2005, 06:46 PM
  4. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  5. 2001 BMW M5 MP3 project
    By cjones in forum Show off your project
    Last Post: 10-01-2003, 12:47 AM
