does that ground loop isolator work?
Well i just realized that after having my system done for over a year and a half i have yet to post the photos here.
My goal here was to make no mods to the car interior, so i have made the screen just snap in, the computer brackets just bolt to the factory holes, and all wiring was run in a single harness.
Power was taken from the fuse box using a fuse tap.
PC Specs
Screen: Lilliput 619
Motherboard: Jetway J7F3E
Processor: 1.4GHz AMD Geode
Memory: 512MB
Hard Drive: 40GB Seagate
Front End: StreetDeck
GPS: BU-353
PSU: M2-ATX
Radio: XM Direct
sound card: Creative PCMCIA Audigy Zs
The Factory monsoon amp is used with the Custom Amp turn on circuit that is powered by the M2-ATX Amp Pins.
The Screen is mounted in my VW Bezel that i have designed and have started to get produced. Will be available soon on the MP3CAR shop.
I mounted the PC on L brackets that i re-drilled the holes to match the holes from the factory cd changer bracket.
You can see a article i wrote about it last year here:
http://www.geardigest.com/2006/06/22...ur_own_car_pc/
The Car
APR Stage 2 - Magnaflow exhaust - Renner Motorsports 3" custom DP - H&R Sport springs & Bilstien shocks/struts - Neuspeed 32mm rear sway bar.
The Dash
The Car PC
Power
Power
Amp Turn on
1990 Jeep Cherokee
2000 VW Golf TDI 4dr
2005 VW GTI MKIV - SOLD
as from personal experience, it sounds like total **** withought it
Its actually more for cutting the voltage from going back into the sound card, but it sounds great.
1990 Jeep Cherokee
WebDog,
what's the part number of that amplifier/PC bay cover?
