Gotta respect a man that did all that workvery nice install. I went through something simular as I did a complete stereo upgrade and CarPc install at the same time.
P.S
Did you Dynomat or put sound deading in?
'03 Dodge SRT-4: 5U Rack case, Gigabyte GA-G1975X, P4 3.29Ghz, 4Gb ddr2, pci-e 16x geforceFX 7300GT, 500Gb sata2, 2x 160Gb RAID0, 2x 40Gb RAID1, 8" touchscreen, XM, ATSC tuner, 500mw wifi, BT2.0, 5.1 D-Digital, running RoadRunner!
P.S
no, no dynomat. I don't really listen to it that loud anymore. I might be pushing 100w to the sub. I just like it to sound full, and distortion free. Also, soundproofing the car would not help make my car any quieter inside. I have solid motor mounts, and solid torque bars making it so that _every_ engine/drivetrain noise/vibration resonates through the chassis. It was the only way to make it so that if my front tires loose traction, I won't get wheel-hop. by adding the 3/4 inch MDF all through the bottom of the trunk it is a little quieter.
What I need to do is get a battery isolator, and a second battery. I want to isolate the all of the pc/audio to it's own battery. My power supply take so much power that I can't have the computer on for 15mins and my car won't start. well, the 2 Rockford 4 channel, and JBL mono amp also draws a lot. I'm thinking about putting a gel-cell in the trunk. They are made to be charged/killed on a normal basis.
...and on a performance note, I want to find a Jacob's electronics 14v 60A Accuvolt for my pcm/ignition system. ;-)
Wow! FLIR is making a IR Thermo camera for automotive applications! 12Vdc with a normal (yellow) video plug! It's like $4500 for the damn thing, but check youtube for the video! That would be the perfect addition to my setup!
Congrats! v.nice project... those pics remind me of the time when my car was unmouted for the install!
Which TV Antenna did you use? where did you mount it? could you post the link?
the t.v. antenna I used was a cheap ebay 'over the headliner' antenna, it could not get in ANY channels at all, so, now I'm just using some cheap bunny ear antennas in my back window. It was a cheap fix for the winter. I don't know what antenna I'll end up with, but it wont be these ugly bunny ears. :-)
hehe I see, i've had the bunny style antenna for a while.. then found also a cheep normal antenna at a local retailer..
i've found on the net a complete digital in-car receiver with excellent quality over 150km/h! but it costs like 500Euros... I don't think its worst it!
Can't see any pics...
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
The pictures are hosted on my own computer. The webserver runs on port 81. You should not have a problem if you're on your own connection. Most shared connections (most companies, schools, wifi spots) won't allow traffic on that port. try http://www.myspace.com/srt4pc .
oh, I didn't even think of this (just woke up), just click on my public pics in my profile.
...also a carpc sounds kewl in a evo.![]()
