Results 1 to 10 of 10
Thread: My second carputer...
    Constant Bitrate agniusm's Avatar
    Oct 2006
    Lisburn
    Hi every one. This is my second carputer so far first one was installed in citroen Saxo and was not so much special. This time im puting alot more efort.
    First of all spec. and bits:
    CARPUTER:
    VIA EPIA EX 1500MHz
    1GB DDR2 RAM
    160 MAXTOR 3.5" HDD
    SB Live Value
    M2-ATX 160W
    USB WINTV USB
    USB BT
    USB GPS
    USB WIFI
    USB HUB
    Wireles Logitech gamepad
    labtec usb cam
    custom made USB controler(mouse + alps RKJXT1E 4 way)
    7" lct touch screen (could be better )
    SOUND:
    Focal FP 5.500 x1
    SUB focal polyglass 27V1 x1
    Speakers focal polyglass 165V1 x 2 pairs
    3.5mm to rca x2
    Oct 2006
    Lisburn
    Carputer home
    2 months ago finaly found and bought car i allways waned, white VW scirocco gt2. Here she is
    Oct 2006
    Lisburn
    carputer
    I have decided to fit my carputer in front glove compartment. Made bracket from old PC case to fit MB PSU HDD. Here's some pics
    Oct 2006
    Lisburn
    PSU cable
    had to make another psu cable cause the one which came with M2-ATX was to short
    Oct 2006
    Lisburn
    Controller
    Here is my MOUSE+ALPS controller. This will be used with autohotkeys. Learned how to manufacture PCB's
    Oct 2006
    Lisburn
    Light
    Above the carbuter i have placed blue neons, 2 x 10cm and made window at the top of the glove compartment insert:
    Oct 2006
    Lisburn
    Amp box
    Have made AMP box from plywood + some carpet. still need some acrilic to fit window. Inside 2 x 12" red neons flashing by music. Here is the box (let me know what you think)
    Mar 2006
    Colorado, but Canadian!
    Looking good.
    For that window though, will that be visible? Or just so that the neons can make a glow around the box? Because if it will be visible, they make acrylic glue that is clear and wont show that mess around it...
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    Lisburn
    Quote Originally Posted by 2k1Toaster View Post
    Looking good.
    Hej. No, wont be visible at all unless someone will bent in half . As you said its for neon glow on mobo, ram etc.
    Dec 2006
    nice mate i love the way u made the case. did you just cut up an ond one.
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 09:34 AM
  2. Carputer confusion- n00b needing help
    By TonyMartin in forum Newbie
    Last Post: 03-10-2006, 12:11 PM
  3. Carputer confusion- n00b needing help
    By TonyMartin in forum General Hardware Discussion
    Last Post: 03-08-2006, 09:43 PM
  4. wikipedia: carputer definition
    By pRoFiT in forum Off Topic
    Last Post: 12-31-2005, 08:32 AM
  5. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
