Results 1 to 10 of 11
Thread: 2002 Civic Si Install
    Dec 2005
    Raleigh, NC
    My Install
    Hardware:
    • Dell Optiplex GX260
    • P4 2800
    • M2-ATX
    • 512mb ram
    • 80gb WD HDD
    • BU-353
    • Belkin F8T003 (10m bluetooth adapter)
    • 3DConnexion SpaceNavigator
    • Lilliput EBY-701
    Dec 2005
    Raleigh, NC
    SpaceNavigator
    SpaceNavigator with hand brake down for driving:
    SpaceNavigator with hand brake up for parking:
    Dec 2005
    Raleigh, NC
    Screen Pictures
    EBY-701 installed in dash without modification
    There is a little glare but not too bad.
    Closer view
    Mar 2006
    Colorado, but Canadian!
    I always love how the 7th gen civics have the perfect opening for a 7" widescreen.
    I drove around like that for a year before I finally had help filling the gaps. Any plans on finishing it up sometime? I got my spare dash piece off of eBay for $20-$30 (I cant remember anymore), so I can go back to stock easily.
    1.9in x 2.9in -- 47mm x 73mm
    Dec 2005
    Raleigh, NC
    The only gap is the one on the right side. The gap around the top, bottom, and left is actually less than the aftermarket kit I had in there before. I did put a bead of clear silicon along the bottom and left side to keep things from rattling.
    I still want it to look like there's a screen installed. I played around a little with the idea of molding it in, but I bought a warranty for the screen (since they are prone to have issues) and I'd rather keep it unmodified so I can pull it out in the event of a failure.
    I could probably caulk it with some satin black or grey silicon to clean up the edges a bit, how do you think that would look?
    Mar 2006
    Quote Originally Posted by ik632 View Post
    Tried it, it looked aweful.
    I dont have the si though, I have an ex, so the dash was black not silver. So it looked more uniform. I think it just looks a bit out of place.
    Something you may have better luck with is a Metra double-din kit. Then shave away the top, bottom, and left side until it is a tight squeeze fit, and the right side will cover that hole weird shape up. I tried but I accidentally broke mine so then I tried it and some Plast-dip to try and make it look better, and long story short, it was the worst looking thing ever because the filler I used was shiny rubber...
    But I think if you have more patience than I did, and took your time, it would look really good for little work.
    Dec 2005
    Raleigh, NC
    I just went out and measured and there's less than a 16th of an inch on the top right hand corner and top left corner so the fit would be really tight. Are you talking about the 3/16" gap on the left side and bottom? I know that the weird shaped triangular section needs something I just haven't decided yet what. I actually have one of the metra kits sitting on a shelf at home so I can start hacking it up and see what I come up with.
    Thanks for the honest feedback on the fit.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    looking good, how do you like the space nav? clean up the screen install and you got yourself a great looking project
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Mar 2006
    Also as a side, do you have leather seats? I didnt know that was an option on our cars... That makes me sad. Stupid cloth...
    Dec 2005
    Raleigh, NC
    Quote Originally Posted by scott_fx View Post
    I like the SpaceNavigator a lot. I use it mostly for volume and skipping tracks. On a regular day drive to work I don't even have to touch the screen. If I want to load new playlists then I have to touch the screen. I just need to get the hotkey for switching playlists to one of the buttons on the SN.
    As far as the screen install goes, I got the trianglar piece worked out and I'll get some pictures pretty soon. The rest of the gap is too narrow to fit a plastic trim piece in there but I'll post my new solution in a day or two when it's done. I can't do anything permanent (or modify the screen) because it would void the extended warranty that I bought for it.
    Nick - 08 GG Element
    Custom 3D-CAD Design, Reverse Engineering and Fabrication
  1. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  2. Replies: 2
    Last Post: 07-11-2006, 10:50 PM
  3. 99 Honda Civic Sedan Screen Install
    By CustomZ02 in forum Fabrication
    Last Post: 10-07-2004, 10:13 PM
  4. install on a 95 honda civic
    By schrodos in forum General MP3Car Discussion
    Last Post: 11-21-2000, 05:43 AM
