Page 1 of 9 123456789 LastLast
Results 1 to 10 of 89
Thread: 2003 Tahoe Install
    Springfield VA
    2003 Tahoe Install
    Hey everyone, I mostly lurk on this site, but since I've gotten so much info from you guys and I enjoy reading your install threads, I thought I'd share my own install.
    Plan is to install a 10.4" TS screen in the center console of my 2003 Tahoe - making it as factory looking as possible. I'm using an epia 10K board, 512 ram (probably will bump up to 1 gig), 40 GIG HD (again upgraded in the near future), XP pro, Holux GPS mouse and an Opus 150 watt for power supply.
    The first part I wanted to tackle was getting the screen installed. I wanted it where the cubby holes and cig lighter are in the center console. So I pulled that piece out and started cutting to fit the screen.
    The idea was to use MDF and fiberglass, but after talking with Dad, we decided to go with balsa covered with fiberglass. He builds model airplanes so he has a ton of scrap and knows how to work with the wood.
    I used cardboard to mock up how I wanted the final product to look like. Once I was sure of the design (this took the longest part - I probably worked on this for 9 months, on and off), we started building. After about 4 hours in the shop, this is what we have so far:
    We still need to finish up the top corner on the passenger side and put in the pieces that will hold the screen centered on the back. Once that's done, we'll secure the frame to the dash piece, cover with felt and glass. If all goes well, I'm hoping to be laying glass by the end of next week.
    -Matt
    Registered User
    Nice woodwork
    Springfield VA
    thanks for the complements!
    made some more progress tonight - got the passenger side finished up and also fitted the top :
    Then decided that before we glue everything up, we should test fit one last time. Turns out on the passenger side the screen sits about 1/4" too high and hits the bottom of the dash piece. I knew this was going to be the hardest part, but I thought I had it figured out. We removed the bottom piece of the screen bezel and replaced it 1/8" balsa, still too high.
    Not sure what we're gonna do to solve this problem.
    Maximum Bitrate BarryWoods's Avatar
    May 2006
    Ohio
    Fill it and round it over to look like the dash part right above it. I'd actually round over all the outside edges to look like the rest of the dash parts as well. Just keeping the inside square. That make sense?
    Failure is not an option....
    It's installed by default on every version of Windows.
    Springfield VA
    yeah, the plan is to definitely round the edges, but the problem I ran into last night is that the upper part of the dash is actually pushing my bezel down. So even if I were to fill it and smooth it out, I will still have a problem fitting the screen. Theres no extra room in the bezel for me to remove and still have the screen fit correctly.
    Springfield VA
    not much build progress was made last night. Spent most of the time figuring out the best way to fit the 10" screen without hitting that upper dash piece. Finally decided the best way was to forget about attaching the screen bezel to the factory console piece. Instead, we'll be building our own that will install using the factory mounting locations. Will have pictures later this morning.
    Springfield VA
    and the pictures
    building up the bottom again:
    test fitting to make sure the screen clears at the top:
    getting an idea on how the sides will flow with the rest of the dash/console:
    bottom finished, screen taped in making sure we have enough clearance behind:
    the plan today is to finish the sides and top of the new dash piece and if possible, get the screen bezel installed. Then start lining up the mounting points and getting those built.
    While I probably wasted most of the time I have invested in this project - first cutting up the old dash piece and then designing and building a prototype bezel out of cardboard, I think building it up this way will result in a much better final product. Not to mention, it should be pretty easy, now that we have the measurements and all.
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Lookin' good... Figured I'd watch the progress over here as well!
    Play with it, 'til it's broke.
    Springfield VA
    HAHAHAH cool! Be sure to let me know if you need anything or if I can help any way with your install.
    Springfield VA
    made a lot of progress this afternoon (even though it may not look like it). Got the sides and top piece cut and tacked in place. Then we were able to get the new piece in place without any interference from the upper dash like before.
    Then we were able to figure out how we are going to actually secure the new lower dash piece to the rest of the car. Tomorrow, we should be able to knock that out. So hopefully by the end of the day, I will have a new lower dash that can actually be installed, not just held in place.
  1. MP3Car Infill G4 install in a 2003 Infiniti G35 (Moved Threads)
    By voidunknown in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 04-11-2007, 12:37 AM
  2. 2003 Toyota Matrix install
    By Matrix_24 in forum Fabrication
    Last Post: 05-16-2006, 08:01 PM
  3. carputer in 2003 tahoe. plenty of bondo!
    By TahoeZoo in forum Show off your project
    Last Post: 04-06-2005, 08:31 PM
  4. Lcd and Ps2 install in 2003 WRX
    By WRichieX in forum Newbie
    Last Post: 03-10-2004, 10:37 PM
  5. M10000 install - 2003 Mazda 6
    By Litespeed in forum Show off your project
    Last Post: 03-08-2004, 10:45 PM
