Page 14 of 42 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 418
Thread: 03 infiniti fx35 w/all the toys, add a carpc too? oh yeah... :)
  1. #131
    Oct 2004
    NY
    some may question my choice of resistive over either capacitive, saw & ir touchscreens, well, I've had (have) a capacitive & they are just too glossy, I mean, yeah, there 97% light transmissive compared to the resistives maybe 78%, but the glare is a bigger issue, & the resistive is the less of the 2 evils, as far as ir, just no room, & saw same really
    in the end, now that I'm able to do a brightness enhancement from the front also, this worked out to be the best combo I think.
    visability is just not an issue with this screen so far from what I've seen, really can't wait to drive it
  2. #132
    Oct 2004
    NY
    ok, I finally got to test this in the sun, direct & blinding sun, even the glare from the black matte bezel is glaringly white & blinding, but the screen is great... can read it fine, the touchscreen does have that typical milky white kinda look in the sun, but it doesn't hurt the visability of this... the fujitsu antiglare touchscreen is a good piece & does the job well
  3. #133
    Jun 2007
    that's hot good work turbo your installs have always impressed me
  4. #134
    Oct 2004
    NY
    hey, thanks man, this install has gone nice & smooth, no problems or comprimises really, even all the factory stuff is stil intact & funtioning as it should, the only loss is the cassette deck, still don't know what the hell they were thinking by putting a cassette deck in this truck, I'm not missing it one bit
  5. #135
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Looks incredible. Is the OEM screen just mounted up there right now or is there something molded for that?
    On a side note, i was damn glad this weekend to have adjustable vents... my car was overheating on my way home from boston, so I put the heat on full blast (which worked very well to drop the engine temp) and with the windows down it was bearable, but I think I would have overheated if the vents werent adjustable away from me! Granted I hope for everyone that should never be their reason to want adjustable vents, but i thought id mention it anyway....
    Brown 2010
  6. #136
    Oct 2004
    NY
    right now it's mounted but not molded, I have to decide what I'm doing up there, may eliminate the rear view mirror all togeather & have another rear camera for driving, the factory rear camera now points down & it's a fisheye lens, really wide but no distance abilties really, good for parking but not as primary rear view. if I eliminate the mirror then I have no need for a rear wiper, so the second camera would go thru the wiper hole & the wiper eliminated, then I gotta see if I'm going to mount the display of the driverack up there too... that console may take a little while to finalize really.
    tonight I was able to mount the radio & align it with a slot that I made above the clock in the console., I was able to fit it all in there, clock & ashtray even intact... the cd's load & eject nicely, & are guided in by the bottom edge of the upper dash, works pefectly with no jambs or missalignments, smooth you don't even see this slot unless you bend down to look for it, I still need to put a flap inside so it looks finished 100%, but it looks pretty good really, not ugly at all & not even seen mostly.
    I still need to relocate the *slot occupied* sensing switch from the upper orig slot down to the lower, this tells the radio theres a disc waiting to be loaded, but that shouldn't be a problem really, I'll do that when I put the pc slot load drive in the upper opening, so this part is pretty much done too, it's getting there, plates on this thing any day now
  7. #137
    Oct 2005
    Hou. TX
    Doesn't NY require there be a rear view mirror installed?
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  8. #138
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by JasonWW View Post
    wouldn't a camera count?
    1998 Camaro Worklog Starting over, New setup for 2010
  9. #139
    Oct 2005
    Hou. TX
    They don't in TX. Even if the back window is completely blocked, like a wall of subs or something, you still have to have the mirror. It sounds dumb, but it's the law here.
    A simple workaround would be for Turbo to have a friend do his vehicle inspections and hope the cops don't notice or have a simple mirror he can prop over the video screen on certain occassions. I don't know, I was just asking. Maybe the laws are different there.
    CarPC's in F-bodies
  10. #140
    Mar 2006
    Iowa
    hmm, i understand now. we don't have inspections of any sorts here, so i guess I'd only have to sorry about cops (since i wanted a VFD in the mirror)
    I'm sure Turbo already has it all figured out lol
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  3. Team America
    By migel628 in forum Off Topic
    Last Post: 10-26-2004, 07:12 PM
