Page 24 of 42 FirstFirst ... 141516171819202122232425262728293031323334 ... LastLast
Results 231 to 240 of 418
Thread: 03 infiniti fx35 w/all the toys, add a carpc too? oh yeah... :)
  1. #231
    Oct 2004
    NY
    I don't really have a solution at this point. right now I needed the screen usable, but out of the way for the main screen, so I pulled the sunglass holder out of the headliner & hacked a hole in the sunglass holder & just hung the screen off of the metal bulk header in the roof, stuck the sunglass holder back over it & it looks 70% to a casual observer maybe, but not really "good" at all. it could be if I finalized it the way it is & moved the mirror, but I'm not happy with it enough to finalize it so it's just stuck there
    if you make up your mind that you are going to just do it, pull the whole sunglass holder out & you'll see where you can mount to, the rear view mirror looks easy enough to extend. my thoughts are to cut the 2" extention bar & find a tube that it fits in, then black out the tube & epoxy it over as an extention, extend it a bit & it'll be fine... I'm sure the wiring has enough slack for that too, so it should be easy..
    removing the sunglass holder is a real pain, you have 2 choices, remove the headliner & remove all the clips that make it an assembly with the headliner to begin with, & then put the headliner back in & work from there, or actually break it out, trying to not damage the headliner & then go from there. I'll admit that I just ripped mine out, I wasn't going to take the headliner out, my thoughts are if I'm going to take the headliner out anyway, then I would sueade the whole upper interior black, I can do that later so I ripped it out, it didn't really damage anything so it goes in & out from the front now. this was the butchery part I mentioned
  2. #232
    Oct 2005
    Hou. TX
    Doesn't that rear view mirror arm have the 2 ball mounts on the end with the big spring pushing them apart? It seems it would be pretty tricky to make it longer.
    1999 Black Pontiac Trans Am
    CarPC's in F-bodies
    How To Relocate Climate Controls on the 97-02 F-body Cars
    (AMD Sempron 3000+, Opus 150)
    Car PC system is out, Alpine system is in.
  3. #233
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Hummm, I'd be really scared of damaging the headliner. Looks like a pain to fix it, and I'm not sure I have the abilities to fix it. Also have to check the rear view mirror thing.
    Thanks anyway for the quick reply, I'll keep looking for a solution.
  4. #234
    Oct 2004
    NY
    some are press fit, I thought these might be too... if it's a spring then it would be the same really, just an extention for the spring too & a way to clamp it, may need to tack weld it if theres a lot of tention... could be a little bit of a project too I guess... guess I'd have to see it to figure it out, never cut one before really, I guess you have?
  5. #235
    Oct 2005
    Hou. TX
    I've seen a broke one. The main problem with extending that arm is the extra weight it creates. You get a lot more leverage which can make it droop down when hitting a pothole.
    I have no idea what the FX35 one's look like, but on older cars you can twist the old metal tab off the window and mount it lower. Is that an option?
    CarPC's in F-bodies
  6. #236
    Oct 2004
    NY
    hurst, yeah, I guess I keep forgeting about the scary part for many guys... I got over being afaid a long time ago... to do anything theres risks I guess, & you will have to make screwups in the beginning too, but theres only one way to do it & that's to just do it
    what about a sun visor mount? maybe still better than nothing?, at that point you might as well make a pedistal mount & take it in & out. don't know what to tell you really past that.
    you might be able to find a good interior shop that could just do the screen mount & bring the wires down to the kick panel area, then go from there but the finish trim would still be an issue?? fear & car chopping & modding don't go togeather to well
    jason, the extra leverage might be an issue, but I was only thinking may 3/4" - 1" maybe. I did remove a mirror button on my montana, but i wasn't too afraid of breaking the windshield cause it's allready been out, I would hate to break the windshield & have to crack the factory seal in the fx unless I had to, I would try to avoid removing the button but i haven't screwed with it enough to even think about any of that yet really, the extention idea was just a brief initial thought... if I was going to attempt anything like that I'd buy an ebay mirror, but there few & far between, & expensive.
  7. #237
    Oct 2005
    Hou. TX
    If you take a pair of channel locks, lay them against the glass and twist it clounterclockwise back and forth it should pop loose. I've done it several times.
    Or you might just add a second button and leave the stock one in place. I just figured you wouldn't like the 2nd button visable.
    CarPC's in F-bodies
  8. #238
    Oct 2004
    NY
    some come off easier than others, I've done some that were kinda easy & a few that refused to break loose & took glass with them... when I did the montana the windshield was brand new, just put in that day, it took me almost an hour to get it off, vicegrip turning back & forth, cutting in around the edges with a blade and using adhiesive remover and a heatgun from the outside to lossen it up, that was a tough one for sure. I'm thinking when I really get down to it, I'll probably eliminate the rearview mirror all togeather really anyway & it'll be a video camera feed instead.
  9. #239
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by turbocad6 View Post
    yeah, you shoulda seen the techs face at the infiniti dealer when I brought it in for a fuel pump... the guys were bugging out...
    first the service writer had a strange look on his face & was asking for the registration, saying somthing isn't right here, he didn't belive it was an 03, & he got even more suspicious when he put the vin# in & it came up as being silver... then later the tech came to me & was like,you gotta tell me, who did that for you? I said I did it myself & I could tell he just didn't believe me, kept asking if I knew where he could get that done to his car
    ... it was pretty funny really. I've had some customs in the past that i always thought to bring it to a dealer just to see the look on there face, this one I actually had to though I had a riv convertable once with a grand national fwd conversion & brought that into the dealer, the tech there was arguing with me saying that it was factory, the rivs had a turbo option... I had to tell him, yeah, but a 301 pos.. not an intercooled 3.8 sfi that car was a sick ride too btw I still have it, rotting away in a backyard somewhere... one of my first radical customs
    I know exactly what you mean. When I brought the Matrix to the dealer for an oil change and a fuel sender unit, the service writer has a strange look on his face kind of like "WTH, the matrix didn't come with this GPS system."
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  10. #240
    Sep 2006
    any updates? loving this thread. it makes me want to start working on my pc cruiser again.... but its winter outside and my shop isn't done yet
    blueglitch
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  3. Team America
    By migel628 in forum Off Topic
    Last Post: 10-26-2004, 07:12 PM
