Page 6 of 42 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 418
Thread: 03 infiniti fx35 w/all the toys, add a carpc too? oh yeah... :)
  1. #51
    Oct 2004
    NY
    new cars are more & more plastics & composites, & now aluminum is becoming pretty common too...
  2. #52
    Oct 2004
    NY
    ok, heres a little mini welding tutorial, I decided to not use any fillers at all on the face of this bezel, just abs plastic & that's it, since it's such a minimal piece & very flexible, so I will weld in plastic to fill & then sand & shape, the final bezel is one solid piece of abs plastic bezel, like factory.
    the idea is to melt the piece you want to melt to till it's molten, you see I loaded the tip with a piece of scrap from the donor drawer divider, then melt the surface of the bezel with the side of the iron, then add the molten plastic, spread it in & make sure the whole thing is melted & wetted togeather, spred & smooth it with the iron, then when it cools sand it as it was filler, cause it is
    heres a few pictures showing the process:
  3. #53
    Mar 2006
    Colorado, but Canadian!
    Ah man, you got all the cool tools! My only power tool is a drill! I had a dremel but I melted it...
    Looks good!
    1.9in x 2.9in -- 47mm x 73mm
  4. #54
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    thats awsome
    1998 Camaro Worklog Starting over, New setup for 2010
  5. #55
    Oct 2004
    NY
    when this is finished it's just prime & paint, if this is sanded smooth enough, it's almost good enough to just leave raw plastic with no primer or paint, the end result is that good. this plastic welding is the basics of any plastic fabrication I do really, on larger pieces with a lot of bulk & surface area this would normally be welded to the point of rough & then bumper repair would be used as a filler.
  6. #56
    Oct 2004
    NY
    so far I've got over 15 hours into this bezel alone, by the time it's done vents & all I'm guessing around 22 hours total, this takes a lot of patience....
  7. #57
    Oct 2004
    NY
    how the hell did you melt a dremel
  8. #58
    Variable Bitrate P3D4T0R's Avatar
    Dec 2006
    MA, USA
    Quote Originally Posted by turbocad6 View Post
    Ive done it too :shrug:
    "Mess with the best, die like the rest."
    Work Log --> Old Car (Totaled)
    Work Log v2 --> New Car (Totaled)
    Work Log v3 --> GMC Suburban K2500 (Work in progress)
  9. #59
    Mar 2006
    Well after my dad left, hew took all the tools. Everything from the band saw to hand saw. Table saw, screwdrivers, pliers, everything. All that was left to use was a pair of old Kitchen scissors.
    So I bought a bright orange Black & Decker Dremel for $35 from HomeDepot because a project I was working on I wanted to cut it. It was 1/4" plywood.
    So I used those little itty bitty rotating disks to cut with, and after about 1hr of continuous spinning at high speed with my hands over the "vents" that blow out the hot air,where I was holding turned to goo, and started to burn my fingers so I just moved my hand from the vent but it was too late because the metal piece that holds the bit in (still rotating at high RPM) started to wobble and then it flew out! Not the bit itself, but the actual piece of steel formed into the plastic casing to hold the bit and the bit flew out and lodged itself in the ceiling. Well I just put it back in the case and returned it to Home Depot.
    I bought a corded drill instead and that is still the only tool I have!
  10. #60
    Oct 2004
    NY
    the only way you can tell this started out as a bunch of seperate pieces is from behind, I could really get nuts & finish weld it & smooth the seams from behind too, but that might be just a bit excessive, I may be nuts but I'm not crazy... or is it the other way around... not sure right now, too much plastic fumes
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  3. Team America
    By migel628 in forum Off Topic
    Last Post: 10-26-2004, 07:12 PM
