Page 9 of 42 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 418
Thread: 03 infiniti fx35 w/all the toys, add a carpc too? oh yeah... :)
  1. #81
    Variable Bitrate cherrybomb's Avatar
    Apr 2005
    Southern Califorina
    I found this thread after finishing reading your caddy thread.
    All I can say..
    I hate you......
    In the totally complimentary, jealous, and wish I could do work that good, way though.
    It's stuff like this that makes me wonder if my install is good enough. *sigh*
    Very very very nice. Can't say it enough.
    So totally jealous.
    Now if only it was an FX45..
    '99 Ford Explorer Eddie Bauer
    CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
    CarPC Project Web Site
    SpaceNavigatorDriver SourceForge Project
    Check out my blog.
  2. #82
    Oct 2004
    NY
    ahh, but there are so many more mods available for the 35, both turbo & supercharged & in the end a built 35 will beat a 45 any day it's like when lexus did the sc300 & 400, the 300 was much better with a turbo, which you couldn't do to the 400
    this 3.5 v6 is a pretty stout engine, it's the same as a 350z... plus, I had no choice, none of my customers nearly totaled there fx 45 that week
    my back is out, I can't finish this bezel for another day or 2... pain... sucks....
  3. #83
    Apr 2005
    Southern Califorina
    Quote Originally Posted by turbocad6 View Post
    *nod* true enough. I just had to try to poke some fun.
    I wasn't aware that the aftermarket made the 3.5 more desirable, but it does make sense, particularly since it's the same motor as the 350z.
    Either way, for most mortals I think either motor is probably ample.
    I really REALLY want to swap a diesel motor into my Explorer. When/if the motors start coming out for the 1/2 ton trucks from the "Big 3" I may have a fighting chance to adapt one to my application. The "hard part" will be getting all the electronics right.
    I particularly like the 4.5L Duramax that GM has announced. It's claimed to be "the same size" as an LS motor, so I should have no problem fitting it.
    Anywho, that was totally off topic! Forgive my rambling!
    Bummer about your back. Get some rest, so you can get back to the bezel and make me even more jealous.
    Check out my blog.
  4. #84
    Maximum Bitrate Sidewalksalvage's Avatar
    Mar 2006
    NJ/RI
    Damn, that bezel does look damn flawless!
    Whats the paint you are using? its just about exactly what I have been searching for.
    Sorry about the back, hopfully youll feel great soon.
    P.S. I love the "Big Misteak" eraser... i had one of those at one time.
    Brown 2010
  5. #85
    Oct 2004
    NY
    not flawless yet, but getting there...
    that paint in the first painted shot is a sem trim black, it dries not completely flat, but a low sheen, I like to polish it & then it has just a bit more shine, but still low to medium gloss
    this bezel just has way to much fabrication & welding to be able to get a flawless finish without at least some primer, thought I could just fill with the trim paint, but by the second aplication I saw it just wasn't gonna happen, so I primed & blocked it, the I used a black laquer that I have, it has a bit more body than the trim paint, I could then wetsand it & trim paint it for a flawless finish, or I could spray some texture on it, then spray it with the trim paint, or... I could just polish the black laquer... that's really a nice look, it's shiny but not as much as a clearcoated piece... it's maybe 75% gloss...
    if I did this I would then do the center console & door trim all to match, black laquer trim through out might look cool...
    still havent decided 100% on the finish, but I still have to work out the vents & ductwork before final finish anyway...
    this is so far..., the laquer was sprayed with a few heavy coats to allow wetsanding, so it has a heavy peel effect, this would go to smooth as glass when polished though...
  6. #86
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    If you're going to paint some of the interior pieces, it would be cool to do it in the same paint as the exterior. I love that exterior paint, still drooling over it even after a few days!
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  7. #87
    Oct 2004
    NY
    I thought about that but it might look like too much, might look cheap, most times I see interior stuff painted to match the outside it just has a cheap look to it, I think just black laquer would look more classy...
  8. #88
    May 2007
    Lakehood, CO
    you're right, sometimes that looks cheap.
    have you ever seen flat black covered with high gloss clear?
    I think if you get the right flat black it looks amazing, when light shines on it, it's a glossy black, otherwise the flat shows through. It's hard to describe it though.
    For you, I think the laquer black would be awesome, if you do it right. Paint just the right pieces, and have restraint to not paint the wrong ones. Too many times someone gets a can of interior paint, and just takes apart as much of the dash pieces as possible and starts spraying them without thinking of the final product.
    Of course you will get it right, just warning those subscribed here about it...
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  9. #89
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Ah turbo, your installs never cease to amaze. So I take it the driverrack unit will be making it's way into this car instead?
  10. #90
    Oct 2004
    NY
    I've been thinking about that very thing past few days, I'm hesitant to say "yes, it's going in"... I've been so wrapped up in the dash & body of this car that I haven't really measured anything really. I'm considering the audio at this point.
    for me to do "my system" I really want 8"s in the doors, & I really want my horns under the dash... this is the only vehicle I've ever bought that I didn't confirm this fitment before I bought it..., broke my own rule for this fx
    If I can't fit my big stuff for my front end then I don't know what I'll do... I haven't really looked at components in years, & I think the only way way I'd get enough bass up front is with a 3 way if I can't fit my 8"s & horns. I hate 3 ways but might do it if I have no choice... I don't think I'd be happy with just a 6 1/2 component set... maybe with a sub in the center console???
    I haven't even lifted the tire cover in the trunk yet, but this thing is much smaller than what I'm used too... I may have to keep this system small & efficent, but I can't stand a wimpy system, I like a lot of spl & clean & accurate,
    at this point I'm not sure what I can do system wise,if I can't go all out then I may not bother doing the driverack in here, just want to get the dash togeather & get plates on it..., haven't even driven it yet even, I'm guessing I'm gonna fall even more in love with it & then have to go off with the system, but we'll see
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. TT Sirius USB interface
    By Pyrotek in forum General Hardware Discussion
    Last Post: 09-08-2005, 09:15 AM
  3. Team America
    By migel628 in forum Off Topic
    Last Post: 10-26-2004, 07:12 PM
