Page 5 of 10 FirstFirst 12345678910 LastLast
Results 41 to 50 of 97
Thread: 2005 Nissan Altima Carputer
  1. #41
    Aug 2007
    Quote Originally Posted by grahamsw View Post
    Do you have a link to where you got your power switch and Hdd/Power status pod? (the one from France) Im looking for a something like that that is neatly enclosed.
    you can make one yourself with two buttons and two leds!
  2. #42
    Low Bitrate dmart23's Avatar
    Oct 2007
    sweet, very inspiring.
  3. #43
    Sep 2007
    Santa Cruz, CA
    Hey Checksum,
    I have a 2004 altima 3.5 that I am getting ready to outfit. I was wondering if you replaced your alternator or not? I imagine all those screens, the puter, plus whatever audio you have must draw a lot. I am looking at a lot of amperage but if you are using stock alternator then I may have hope without investing 600 bucks in a custom one.
  4. #44
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    I am using the stock alternator and the same stock battery, so far everything is running great, and I use it almost everyday aloud volume.
    2005 Nissan Altima - Completed 2007
    2010 Nissan Altima - Coming Soon...
  5. #45
    Sep 2007
    Santa Cruz, CA
    Good to hear. Do you know approx. how much amperage ur pulling?
  6. #46
    Dec 2007
    wowoowow i'm impressed!@@ great job man
  7. #47
    Constant Bitrate almera's Avatar
    Aug 2004
    Very nice and clean install, you've put a lot of effort, one thing; would it be better to relocate or hide that USB socket
    cheers
  8. #48
    Feb 2006
    Columbia/MD
    Quote Originally Posted by cpsubrian View Post
    My 550W speakers are connected to an inverter, they are pulling between 4A and ~10A depending on the loudness *see: Why not PC speakers?
    The first picture is when the PC is IDLE, the second is when I was encoding a MP3 file to stress the PC.
    The computer is pulling between 7A ~10A, and each screen is pulling 1A
    Overall you are looking at ~15A to 25A max
  9. #49
    Sep 2007
    Santa Cruz, CA
    WOW... thats really low. Those PC speakers must be much more efficient than car audio. My sub amp alone can pull up to 100 Amps, although at my normal settings its more like 30A. Then my 6 channel amp probably pulls another 30 Amp. Then add the computer.
  10. #50
    Feb 2006
    Columbia/MD
    You have to remember that this measurement was made with the volume only 1/2 way ( you can see I even mentionned it in the picture), and the meter was reading 9A. I did not want to go any higher with the volume because that meter has a fuse rated at 10A and I did not want to blow it.
    I am sure the amperage curve will be higher as you increase the volume and outputs lots of bass..
    I have never measure the current draw at max volume since my meter rating does not go above 10A.
    But theorically 550W would draw 45A on 12V
  1. 2005 G35 Carputer CONOPS
    By kermitbuns in forum Newbie
    Last Post: 05-14-2007, 09:17 AM
  2. Carputer for 2005 Nissan Altima
    By checksum in forum Newbie
    Last Post: 03-24-2006, 01:08 PM
  3. 2005 Nissan Altima
    By edrex in forum Worklogs
    Last Post: 03-22-2006, 09:56 PM
  4. 2005 Nissan X-Trail SE
    By ecrase2500 in forum Worklogs
    Last Post: 10-16-2005, 06:47 PM
  5. Carputer in Nissan Primera
    By Primera in forum Newbie
    Last Post: 04-21-2004, 01:50 PM
