WOW, that is one hell of a backup plan. Nice install. Those relays don't mess with the quality of the audio....or burn out for that matter?
Just got the major stuff installed and working in my work truck, a chevy astro panel van. (sorry that the pics look aweful)
Specs are:
Shuttle SK41G Case/Motherboard
AMD Athlon 2600+
1GB RAM
60GB HD (probably going to die soon)
Nvidia GeForce4 Video
Opus 150W DC-DC power supply
15" Touchscreen Monitor
Ram-Mount with VESA plate
150W Inverter
XM Direct tuner / USB Adapter
USB GPS
Alpine MRV-F450 5-channel amplifier
Better picture of the ram-mount
It connects to the seat bolts. computer is behind the passenger side seat, I put a 120mm fan on the front of it, as well as an 80mm fan directly under the hard drive
Couldn't find an affordable dc-dc power supply to run my monitor, it wants 48W at 12V, so i got a cheap inverter. Later realized that the inverter goes into "low voltage" mode if you switch the 12V power going into it which requires a manual reset. so I hacked it and wired the switch to a relay and wired the power to constant 12V.
My rats nest of wires, which is conceiled pretty well, as well as the amplifier
One important issue for me is to be able to keep the factory deck functional for downtime (which I'm pessimistic enough to expect plenty of). Each speaker lead is wired to a relay, NC connected to the amp and NO connected to the factory deck, and the coil is energized by a relay connected to the power antenna wire on the factory deck. So when the head unit is turned on, the speakers are switched to the head unit. don't know if this is overkill but i'd rather be safe than sorry
Nice VAN!!!!!!!!!!!!!
Mine is a cargo van too. Used to be a work van, not so much anymore.
http://www.cardomain.com/ride/2932891
My Worklog
I'm using my carputer 100%, but I still need to make it easier to use.
