i thought the rearview was only LCD not vga? are you doing a dual monitor so u can have a front end on the main screen n navigation on the rearview lcd??
They make isolators for video, but they aren't cheap. Easiest thing to do is to do it right. Seperate your power and video cables, make sure the wire you are using is sufficient size, and everything will be ok.
1.9in x 2.9in -- 47mm x 73mm
Well the mirror is not VGA but it has 2 composite inputs, one is for the backup cam and the other is for the secondary monitor on the G4 (the G4 doesn't even have a VGA out Grrrr ) the other cool thing with the mirror is that it is also a bluetooth handsfree device. IDK how they sell that for $150. I love eBay![]()
William,
The more I look at this site the more I want to install a computer in my car. I was just curious, how did you go about mounting that screen in the dashboard?? Was it easy to do??
Thanks,
Kyle Jones
So did you have to cut up the original dashboard, or did you order a different piece??
Kyle Jones
I can't seem to find one. Do you know who manufactured it??
Scosche they make dash kits for almost every car go to Scosche.com and look. also you should get a wiring harness so you dont have to cut your stock harness.
Cool thanks. Any other tips??
Kyle Jones
