Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 2007 Mitsubishi Eclipse GT + Infill G4 & Multiple LCD's
    Jun 2007
    Califon, NJ
    I just finished my project with my car.
    Finished Interior
    License Plate Camera
    then under the hood there is a AEM cold air intake. (I actually had to take off the cold air intake because Mitsubishi would not service my car. the engine light was on for a evap system leak and they still didn't service it even though its a totally different part of the car, also AEM says that their cold air intake wouldn't void my warranty but they didn't say the Mitsubishi was going to be a ***** about it).
    Here's the exterior of the car. there are no mods
    There's me sitting in the Uber Mobile.
    Construction
    Specs
    - Infill G4 Car PC : Centrafuse Frontend.
    - Performance Teknique Rear-view Mirror w/ 7' TFT LCD + Bluetooth.
    - Adesso Wireless Keyboard w/ Touchpad + Custom Mount.
    - Escort 9500i GPS Radar Detector.
    - Rearview Camera Drilled Into License Plate
    - Infinity Basslink Subwoofer
    - Infinity 3-way Speakers
    May 2007
    nice =]
    Jan 2006
    looks good! i would loose the keyboard and use an on-screen solution.
    and your ground loop isolator should be a bit far away from the audio source, not tied to it
    Jun 2007
    Califon, NJ
    well the ground loop isolator worked fine when it was attached, unfortunately I connected the XM adapter in reverse Polarity and the thing was smoking and almost caught on fire so now i don't need the ground loop isolator. o and one question do they make a video ground loop isolator, and if so does it work well because i have image shaking on my mirror LCD every-time the car is running.
    Oct 2006
    Ground loop isolators should never be permanently installed in anything. They are a diagnostic tool, not a fix to the problem. If you need a ground loop isolator to get rid of noise, guess what, you've got a ground loop! Do it right, lose the isolator, find the source of the ground loop, and fix it.
    Feb 2007
    Long Island New York
    what kind of navigation r u using on the rear view mirror lcd?
    Jun 2007
    Califon, NJ
    Quote Originally Posted by pjloppez View Post
    iGuidance v4.0
    Jun 2007
    Califon, NJ
    Quote Originally Posted by spoonraker View Post
    Doesn't the alternator put out ground noise? because when i turn off the ignition the noise goes away.
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by williamcfrancis View Post
    Yes the noise comes from the alternator (AC) and when you run off of the battery you are feeding DC.
    But the point is that if you isolate the power wires from the sound wires, you wont allow the interference from the power cables to disort the audio. And that is what you should do.
    I think it is perfectly ok to leave a GLI in place, but it should be a last resort. Also it degrades the audio quality severly, and anyone with an ear for sound that rides in your car, will instantly know, and no matter the quality of all the rest of the work, that automatically puts you in a lower quality/grade install category.
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2007
    Califon, NJ
    Quote Originally Posted by 2k1Toaster View Post
    Well the thing is I'm not even using the XM radio module anymore (Ismoked it when I plugged it in on reverse polarity LOL. But on My Rear view mirror LCD I even notice Ground Noise. is there a way i can fix this for video.
  1. 2007 Saturn Vue: Infill G4 Worklog
    By JasonMK in forum Show off your project
    Last Post: 08-25-2008, 05:18 PM
  2. INFILL G4 - Australian and New Zealand Questions Answered
    By INFILLG4 in forum General MP3Car Discussion
    Last Post: 04-30-2008, 12:21 AM
  3. G4 with Infill Station
    By flapster in forum Mp3Car Infill G4 - Double Din Car Computer
    Last Post: 01-10-2008, 08:27 AM
  4. CF 1.2 on Infill G4
    By SUNAJ in forum Centrafuse
    Last Post: 08-21-2007, 07:38 AM
  5. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
