I am speechless!!! Congrats.
Maybe someone would like to develop a skin specifically for the DeLorean. RR and DigitalFX is fine (I use it too), but the DeLorean has so much history that can be encapsulated in a skin with all kinds of visuals.
Thanks.
I pretty much like the skin I have. It has a stainless steel look, which goes well with the stainless steel body panels. Im sure there's a good idea in there for a Back To The Future skin.
Its true the DeLorean has alot of history, not just the film. Im sure theres tons of neat things I could put in there.![]()
Awesome car and beautiful install!
screen is skew
Yes. It may look that way in this photo...
But I did state above the photo "Getting the leather centre console back into position."
So the console wasnt properly seated at that point.
The rest of the photos show it is a perfect fit. If it wasnt, id have changed it already![]()
Another question about the vents? Did you block them off completely so that when you turn the heater on, you're not shooting hot air at the screen? I doubt it'd get hot enough to cause any problems, but I'm just curious.
Also, where did you manage to get a 1.21 jigawatt version of the M2?![]()
The central vents are opened and closed right at the back. Behind the area I took the pipes from. There is a little lever which is operated by vacuum. Ive simply removed the lever so the vents remain closed.
M2? lol Thats a thought, better unplug the flux capacitor then!
That would be one hell of a burn out !![]()
