Results 11 to 20 of 27
Thread: My custom carputer case
  1. #11
    Mar 2006
    Colorado, but Canadian!
    I had the exact same idea when we saw that case in walmart! They sell a $10 poker set with chips and cards and everything and it comes in a case exactly like that. As soon as I saw that, I started thniking of a itx case!
    Nice work.
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    Aug 2007
    New Orleans, LA
    shouldn't this been in worklogs, or some other area like fabrication, since this isn't a finished car?
    Crawdaddy
    1991 Chevy Suburban 1500 w/SBC 350
    2005 Saturn ION 2 sedan
    Suburban Worklog
    "A local New Orleans man says his socks are finally dry..." -Tom Tucker, Family Guy
  3. #13
    Low Bitrate ilyassx's Avatar
    Oct 2005
    Belgium, Denmark
    Simple, compact and pretty and really in this way, it will be easy to take off the computer of the car.Perfect I like it!!!
    The old setup http://flickr.com/photos/ilyassx
    The new setup http://my.opera.com/ilyassx/albums/show.dml?id=110701
    Jetway J7F2WE VIA C7 1.5 GHz
    512 DDRII 533
    3.5" SATA2 H.D.D 200GB
    M1-ATX
    ELM327MS OBDII
    Creative Audigy 4
    PROGRESS:[########-]90%
  4. #14
    Low Bitrate iselfdevi's Avatar
    Jul 2006
    Quote Originally Posted by Crawdaddy View Post
    The car is finsihed dude. This case was just an upgrade to setup.
  5. #15
    Jul 2006
    Quote Originally Posted by Mr_Civic View Post
    Very nice work! Have you thought of where you will be placing it while in the car?
    Its under the passenger seat. This case is only 3 inches tall so it was a perfect fit.
  6. #16
    Mar 2007
    Quote Originally Posted by 2k1Toaster View Post
    Nice work.
    I used that exact poker case you're talking about, got it done this weekend. intel mini ITX and a hardrive fit perfectly in there, however, the case is made cheap and light so you must be careful during drilling and cutting. Also, there is not enough head room to close it when you put in the psu wires, now I could go nutts and make custom short cables but that is way too much work for a cheap case that probably won't last more than a year.
    i'll probably buy a vroom itx case and next time i have to do major work on the pc, i'll swap it out. (if it fits where i want it too.)
  7. #17
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    This is badass!
  8. #18
    Mar 2006
    Quote Originally Posted by Snortonnorton View Post
    Cool good to know. I have a Commel board with a P4M on it with a 1U heatsink/fan. I think it will be big enough and if I just cut a hole nad put a fan grill on the exact spot that the fan is then it should work out ok. My only concern would be it overheating. I think I can route power cables no problem. When you say the HD fit, is that a 2.5" drive? I am having trouble picturing my 3.5" drive fitting it there without maybe a hole on the side for it to stick out a bit.
  9. #19
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    Dude - Beautiful - Nuff Said.
    VER. 3.0- Check out below:
    車コンピュータ 3.0
  10. #20
    Oct 2006
    awesome idea for a case. i'm going to see if i can fit one under my passenger seat.
    just so people know this case measures 11.5" x 7.5" x 3"
    can you give out some details of what you have stuffed inside that case?
    i hope your planning on doing a write-up for this because i bet alot of others would love to do the same
    95 Mustang 5.0
    Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
    80% done
  1. Custom 1.6mm Thick Aluminum Carpc Trunk Case
    By LiquidKernel in forum Fabrication
    Last Post: 06-08-2008, 02:52 PM
  2. FS: Complete custom Carputer 50
    By ampy549 in forum Classified Archive
    Last Post: 06-11-2006, 12:58 AM
  3. Custom mount for my OPUS 150W in ATX case
    By Sham-Mobile in forum Power Supplies
    Last Post: 10-10-2005, 11:00 PM
  4. Consider not building a case for Carputer
    By antimatter in forum Fabrication
    Last Post: 05-20-2004, 01:00 AM
  5. digital out on the soundblaster live card and makeing a custom case
    By donalson in forum General Hardware Discussion
    Last Post: 11-27-2000, 06:17 PM
