Quote:
Originally posted by UncoCow
ok had it working driving around today :)
but damn australia, was working fine driving around..... stop in a car park in the sun with a mate and BEEP BEEP BEEP overheating alarm after 10 mins :(
i have an 80mm ball bearing fan on the case and the normal CPU fan....... maybe i need a bigger heatsink/fan..... or maybe i just can't run it in extreme heat while im stopped?
do what the pc modders/overclockers do. Put as many fans in there as possible! Make fan slots to put new fans in, make them big, turn them up! Noise isn't a problem in a car, but power might be a small issue. Then again, they are fans..... how much power could they use?! or if you wanna get real crazy, watercool the punk!
