Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Mr2 install Dell sx260
  1. #11
    Aug 2007
    Chanh55
    wiring diagram, the switch is on the rem line so i can manually turn on/off. You can put a relay in the power line like some people if you are worried about power drain, but i emailed the manufactures and they said best not to and in any case it only pulls milliamps when off so wont be a problem.
    Az, where would be the best place for the power block, i see what you mean, would it on a vertical chassis member be better?
    Rich
  2. #12
    Oct 2007
    Westminster, CA
    Quote Originally Posted by rev1richie View Post
    Chanh55
    Rich
    Thanks Rich.
    What does the "To Lead From Brick" mean...
    Also did you solder directly to the on/off switch on the Dell board?
    Did you put the PS in an enclosure with a fan like the Supra guy did?
  3. #13
    Aug 2007
    chan
    The power lead that comes with the sx260 includes a transformer to step down from high volts to 12 v, Pc's have it inside the case, this is how dell manage to make the sx260 a very small form factor. the lead from this "brick" to the connector that plugs into the PC needs to be cut and spliced onto the molex connector that comes from the DSX
    Yes i soldered directly to the underside of the Mb, you have to dismantle the casework totally to do this, dont force anything, if you get stuck, give me a shout.
    i put the DSX in a little project box with a fan to keep it cool
    where are you based?
    rich
  4. #14
    Oct 2007
    Westminster, CA
    chan
    rich
    You think you can take a pic of the Molex to Dell brick set up when you have a chance?
    I'm all the way over here in California, US.
  5. #15
    Aug 2007
    chanh
    thats going to be difficult, its all fitted behind the capeting in the bulkhead, i tell you what, i've got another 260 at work , i'll take a pic of the psu lead and try some instructions, or send me ticket and i'll come over and do it for you, the weather here is *****
    Rich
  6. #16
    Oct 2007
    Westminster, CA
    Hey richie how did you wire up the amp? Sorry for all the newb questions.
  7. #17
    Aug 2007
    chanh55
    sorry for delay, been in hospital with nerve problems in my my leg, 3 months recovery!!
    the amp was wired up as normal to the power, if you look at the picture of the power block in the front of the car, you will see 2 red leads, one is for the pc psu the other is for the amp, the amp is connected via rca/mini jack to the pc audio card, the result is okay but if you are a perfectionist a pcmcia audio card would be better
    rich
  8. #18
    Jan 2008
    "a guy on another forum did it and i just bought it, he did do a pretty well documented thread on its construction if you want it, as for the pc cover, i haven'e started that yet."
    Hi Rich,
    Would you mind sending a link to, or the name of, the thread?
  9. #19
    Aug 2007
    try this, sorry for the delay http://www.mp3car.com/vbulletin/powe...-solution.html
    good luck
  1. Power supply for Dell SX260
    By rev1richie in forum Power Supplies
    Last Post: 09-26-2007, 05:26 AM
  2. Toyota MR2 Install
    By adrian_uk17 in forum Show off your project
    Last Post: 11-19-2006, 12:44 PM
  3. dell sx260
    By xcalibur in forum Power Supplies
    Last Post: 10-28-2006, 09:03 PM
  4. New Dell SX260 $549
    By Typhoon747 in forum General Hardware Discussion
    Last Post: 11-05-2002, 02:02 PM
