Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Like Tree1Likes
Thread: 2004 Trailblazer RR-DFX2
    Newbie MarkCox's Avatar
    Mar 2007
    Tennessee
    Check out my custom Chevy Trailblazer touchscreen that sits high on the dashboard like a screen ought to!
    I took these at night so they are hard to see clearly. I'll get some more up soon. I'd still like to try and get a copy of the Trailblazer round logo if you find time to take a picture of it or something.
    Aug 2007
    ummm is there supose to be a picture here
    Aug 2007
    sweet whare did you get thoes vents from and do you think i could shoe horn a 10.4 in there
    Mar 2007
    Tennessee
    Vents are completely functional
    The vents are functional. I went to a junk yard and walked around for over an hour trying to find the smallest vents I could find. I ended up getting them out of a 1996 camaro. Actually, I had to get them from two different Camaros as there is a big one and small one on each car above the instrument cluster. I did not damage or alter anything on my Trailblazer to do this install. I cut a peice of plexiglass with 2 holes the size of the vents and mounted 2 peices of old flexible vacuum cleaner hose on it with bondo body filler. I then simply put a screw in the middle and mounted in the hole where the factory vents butted up against it. It was quick and simple to do. I left a small gap from the hose to the new vents to allow air flow to keep heat from building up from the 8.5" LCD touchscreen. The 8.5 screen is as big as will neatly fit into the recessed original vent housing hole. Putting a bigger screen is possible if you eliminate the vents altogether. I recommend not going any bigger because it will block your view. This one is about two inches above the top contour of the dash.
    Jan 2004
    Illinois
    What year camaro?
    What year camaro did the vents come from.?
    thanks
    Mar 2007
    Tennessee
    I believe it was a 1996 or close to it. Check out this google search image.
    http://www.texasinterceptors.com/images/b4c_dash.jpg
    Quote Originally Posted by Tzunami View Post
    thanks
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Good idea on the vents and monitor placement.......makes me rethink my current Blazer set up
    "A rose by any other name is still a flower"
    thekl0wn's Avatar
    Apr 2005
    PoCo, Indiana
    Very nice! Looks like a factory option... Only slicker!
    Play with it, 'til it's broke.
    Newbie MZDASPD6's Avatar
    Oct 2006
    Ontario
    Thats a nice screen setup... Nice job.
    2006 MAZDASPEED6
    Black on Black & White interior
    Powdercoated black OEM 18" Rims.
    Newbie Emad's Avatar
    Sep 2003
    Cairo, Egypt
    very nice job with the vents
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 04:17 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  3. Editing XM playlists in RR
    By mbayers in forum Road Runner
    Last Post: 08-30-2005, 03:44 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
