Results 1 to 10 of 12
Thread: 2006 - Vw - Gli
    Sep 2007
    2006 - Vw - Gli
    Here is my finished Car PC. It's an 8.4 inch screen and it was a bear to get it to fit with a factory look.
    Sep 2005
    Pomona, CA
    What did you use to give it that rough look on the left and right of the screen?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Sep 2007
    It's pretty standard ABS Plastic. I got it from a local car audio shop.
    Low Bitrate 20mg's Avatar
    Oct 2007
    chico ca
    sweet install. looks really clean.
    Jan 2004
    Illinois
    How big is the full opening?
    How big is the full opening? Would a 10.4 fit inside it?
    thanks
    Cliff
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    No way 10.4 will fit.. Here is mine. its 8.4"
    Sep 2007
    Yeah I agree.. My 8.4 inch screen touches the top of the AC controls and I had to remove the knobs that close and open the vents. The top is touching the bottom of the vents. Maybe some sort of widescreen 10 might fit. If someone gave me some physical measurements I would check to see if it fits..
    May 2003
    Florida
    Why did you take the knobs out?? mine fit in fine??
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by mrcoolgli View Post
    Quote Originally Posted by kickercivic1 View Post
    Looks like his is 4:3 and yours is 16:9...?
    Sep 2007
    Yep, Mine is not a wide screen. I got a deal on the screen. Maybe I will switch to the widescreen. Yours looks very nice.
  1. 2006 VW Passat Variant CarPCed (56k beware!)
    By andro in forum Show off your project
    Last Post: 10-09-2007, 10:53 AM
  2. Lilliput 8.4 Inch in 2006 VW
    By mrcoolgli in forum Input Devices
    Last Post: 09-17-2007, 02:14 AM
  3. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  4. 2006 MKV VW Rabbit 2.5 Work Log
    By stangg172006 in forum Worklogs
    Last Post: 05-10-2007, 01:30 PM
  5. 2006 VW Jetta 2.0t
    By dima237 in forum Show off your project
    Last Post: 11-29-2006, 02:47 PM
