Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: 07 Scion Tc
  1. #31
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    i'm using the stock hu i just relocated it, i waned to be able to use my steering wheel controls and if i removed the stock hu i would loose those.
  2. #32
    Maximum Bitrate sporty_drew's Avatar
    Mar 2006
    Iowa
    Quote Originally Posted by Injector View Post
    Not necessarily. You could wire them into the buttons on a game pad and then get a program called joytokey and map each button to a keystroke and implement that into roadrunner
    1998 Camaro Worklog Starting over, New setup for 2010
  3. #33
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by sporty_drew View Post
    correct. i never said that keeping the hu was the only way, but my steering wheel buttons work by resistance from the same 2 wires, which makes things a little more complicated so i said the hell with it and bought a car2pc adapter
  4. #34
    Apr 2008
    Just a thought, but wouldn't it work better with a power diode between the battery and the cap?
  5. #35
    Mar 2005
    Rockledge, FL
    i haven't been able to find a diode big enough to handle the amperage that flows through the cap at start up
  6. #36
    Aug 2008
    So you only had to order the Mechatroniks kit, and use http://retailer.installationexcellen...productid=8563 to install the LCD in your dash?
    Did you have to fab anything on the dash, or just bolt on those two to make it work?
  7. #37
    Mar 2005
    Rockledge, FL
    i bought the kit with the screen, all you have to do on the mounting kit is to move the screw holes about 1" towards the screen so it fits behind the waterfall, apart from that it fit like a dream, what i did is i used a dremel to make the opening longer,
    from this (______) to this (_____________), the longer hole allows for a perfect fit. and the beauty of the kit is that you can buy a screenless kit and put your current screen in it
  8. #38
    Apr 2008
    Too small diode
    If you are talking about burning out the diode when the cap is discharged AND you are starting up then you would need a current-inrush limiting power resister in series with the diode to slow down the capacitor charging rate. During normal operation, if sized properly, the resister would have no effect.
    When the cap is fully charged and you are starting the diode would prevent the starter motor from robbing voltage and charge from your capacitor needed to keep the computer in hybernate until the alternator pulls the system back up to 14.7 volts.
  9. #39
    Jan 2008
    Question
    i t think i understand the question, the screen i used is an eby701 with the me mechatroniks kit
    http://www.mechatroniks.com/wrx/ordering.html
    for the automation i used the kit from tcover.net
    you said you used the lilliput EBY-701 LCD. Is it the newer 08 model? Did you have to modify it in anyway to fit the mechatroniks kit? Did you have to modify the kit to fit into the tC?
    Thanks!
  10. #40
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by vijainair View Post
    Thanks!
    i bought the kit with the screen already installed
  1. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  2. 2005 Scion tC
    By lebshiff21 in forum Show off your project
    Last Post: 05-25-2007, 01:49 PM
  3. Scion tC stock radio
    By Hcomplyr in forum Car Audio
    Last Post: 03-20-2007, 06:05 PM
  4. DVD Receivers (07 Scion tC)
    By th3answer in forum Newbie
    Last Post: 01-22-2007, 02:58 PM
  5. '06 Scion tC
    By oddx in forum Newbie
    Last Post: 03-08-2006, 06:47 PM
