Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Boot in 15 sec!! - Sold State w/ Dual Core Turion **VID**
  1. #11
    Mar 2005
    I was trying to find something to disable the RAM check. Couldn't find it
  2. #12
    FLAC sama's Avatar
    Feb 2006
    London, UK
    if you set all the things in the bios that are set to auto, to manually be the settings they should be (like drive settings) it'll be slightly faster
  3. #13
    Mar 2006
    Colorado, but Canadian!
    and disable USB support in BIOS (thats a big unneccessary chunk). Set the primary drive as the boot drive, disable other bootable devices.
    1.9in x 2.9in -- 47mm x 73mm
  4. #14
    Maximum Bitrate americasfuture2's Avatar
    Apr 2007
    Edmond, Ok
    wow. just wow. is it even worth my time to look for one for my pandora?
  5. #15
    Use a better motherboard mate. Should see it speed up ALOT.
    The turion is a better processor, has better response timing than intels.
  6. #16
    Mar 2005
    Quote Originally Posted by sama View Post
    Quote Originally Posted by 2k1Toaster View Post
    Thanks! I'll try these suggestions.
  7. #17
    Apr 2007
    Edmond, Ok
    i think i will do this as well. i hope i will see a decent amount in bootup time. im gonna try it on my truckputer and my laptop.
  8. #18
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Are you using a stripped out version of XP or just a straight install? Using a stripped version will half your windows load time.
    I'm using a stripped out windows xp with a standard 80gb hdd on an Epia M10000 and I've got a cold boot time of 12 seconds.
    I installed my carpc into my pet Kangaroo, mate.
  9. #19
    Mar 2005
    No, using a full version. What do you do to strip it down exactly?
  10. #20
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    I don't think Windows is really slowing you down based on the video. The BIOS takes most of the boot time...
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. How can I setup a dual boot system ?????
    By tolisn in forum Operating System Optimization
    Last Post: 10-14-2007, 07:53 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. Core Duo/Core 2 Duo processors
    Last Post: 02-06-2007, 09:00 PM
  5. mmmm.. dual core w/ hyperthread = 4 processors
    By Don 944 LA in forum General Hardware Discussion
    Last Post: 07-11-2005, 09:34 AM
