Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 51
Thread: My Lexus SC300 install
  1. #21
    May 2007
    Bothell, WA
    okay..so its been a while since i posted..been kinda busy. but here are some shots of where im at now. im not yet completely done. right now im just running off of a power inverter and not the power supply i ordered yet. so everything right now is just a beta fit.
    this is a shot of the glossy paint i got..before i repainted it again because it was too glossy.
    and this is one of it not glossy anymore. this time i used some trim paint which matched a whole lot better and looked so much better than the glossy
    another shot of it in the car
    and one last shot.
    i have to do a few minor touch ups when i reinstall it again. some things worked out better than i thought, and some not so well. i really need to get another amp for my sub, because the sound sucks with no sub..haha plus, for some reason, when i plug in my speakers to my comp, theres some static, and i dont know why. but when i plug them into my ipod, i get no static. any help there? i got new front speakers too, 4" alpine, as for the rears, i havnt changed them yet. they're still the 4" stock pioneers. i got some nice 6" jl audios for the rear i will install later.
  2. #22
    May 2007
    Bothell, WA
    i kinda have this problem when i connect my carpc to my sound system. i have all my speakers connected to my amp, which then connects to my carpc via an rca to 3.5mm jack cable. when i connect it, theres this static type noise also going on, like when a cell phone gets a call, and your speakers do that static noise, but this is consistent, and doesnt stop. can anybody help? why it does that? when i connect it to my ipod, it makes that noise too, but not as loud, and only sometimes happens. unlike with the carpc, it happens all the time and loud. any ideas? thanks in advance
  3. #23
    Oct 2007
    Westminster, CA
    Thumbs up
    Good job on the fabrication. Have you thought about painting it the stock tan color and painting the center black to make it look stock? All black looks kind of weird imo.
    What's plugged into your cigerette lighter? I remember when I had my Ipod plugged into my cig lighter it made feedback. Right when I unplugged it, it stopped. I hope you're not using an inverter to power your CarPC!
    Also another reason you might be getting feedback is from using cheap RCA cables. Upgrading to better cable ie Monster Cable might help.
  4. #24
    Jun 2004
    Orange County
    Oh wow, how much you've done since the last time we talked! I have to scan those headunit wiring diagrams so you can figure out the speaker wiring.
    Or, I can snap a picture of my amp and you can find the same colors on yours...
    I agree with Chanh55, if you don't have nice wiring, it can be causing a lot of noise. Also, if you have power wire near the audio wire, it can create engine whining noises...
    Lexus SC400
    Subaru WRX Wagon
  5. #25
    May 2007
    Bothell, WA
    oh wow thanks! thats probably it then, the cheap rca cables. i just bought mine from cables to go for a cheap price because i didnt know those would be that important. then i bought some extension cable thing for it, because the one i bought was too short. so ill try with the monster cable.
    and right now, its a temporary setup, but yes, i am temporarily powering it up via a power inverter. thats what was plugged into my cigarette lighter. i just got the power supply, but now i just need to get the aopen power supply adapter.
    as for the color, i think im going to stick with the black all over because my interior is going to change color too. like all the areas which are dark brown color, are going to be black. im actually still unsure if i will stick with either all black, or black center and woodgrain surrounding. ill ps a shot so i can get some decisions on whether to keep it black or woodgrain.
  6. #26
    Oct 2007
    Westminster, CA
    Quote Originally Posted by pnyboy27 View Post
    The Monster Cable isn't cheap so try installing the PSU before you go and buy them. See if that gets rid of the static.
  7. #27
    May 2007
    Bothell, WA
    Quote Originally Posted by chanh55 View Post
    oh yea..i saw that! you're not kidding when you say they arent cheap!
  8. #28
    Constant Bitrate daclothe's Avatar
    Dec 2004
    it's most likely a ground loop problem. if you are powering the comp from the inverter or a cig lighter socket you'll need a ground loop isolator to fix the problem.
    try this, plug everything in, and listen to see if you have what's called alternator whine. when you are in park, rev the engine a bit. if you hear the whizzing sound increase as you're increasing the pressure on the pedal, you know it's a ground loop. the fix is to spend about $18 at radio shack on an isolator. hope that helps!
  9. #29
    Dec 2004
  10. #30
    May 2007
    Bothell, WA
    i think im going to try the better cables first..then ill see whats up. hopefully that'll fix the problem. because i think it might be the cables.
  1. 2008 Nissan Altima Coupe Carputer Install
    By CrackerStealth in forum Worklogs
    Last Post: 01-09-2009, 04:55 PM
  2. VW Golf IV - Mac Mini install
    By Fuse314 in forum Worklogs
    Last Post: 02-24-2008, 05:25 PM
  3. Replies: 9
    Last Post: 09-29-2007, 12:28 AM
  4. PC install: dash vs trunk
    By FreaQ in forum General Hardware Discussion
    Last Post: 09-03-2005, 08:53 PM
  5. windows xp install
    By Moneyfink in forum WinNT Based
    Last Post: 03-09-2005, 01:05 AM
