Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 137
Thread: Fiat Stilo by _Dejan_
  1. #121
    Oct 2007
    Birmingham
    its a shame cux i'd really like to follow this project through but all of the pictures are gone?!?!? Both work and home? hope they come bk soon so i can see! I really want to get mine started, and from all the response here yous sounds great!!
  2. #122
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by chrisghz View Post
    I can normaly see pictures Can you see it now? Im moving pictures to another server and forget change permissions
    I think now will be ok...
  3. #123
    Jun 2010
    You know WAAAAAAAAAAAAAY too much, amazing work
  4. #124
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Here is something new what I will test and install into car when I came from vacation:
    Software:
    Input gain:
    Parametric EQ on input (Same is on each output):
    Crossovers:
    Output gain, time correction and phase:
    One board will be used for TW + MID another one for MIDBASS + SUB, third is input board(optical or SPDIF)...
  5. #125
    Nov 2009
    Peru
    about the circuits...
    Hi what are that circuit board? they look pretty interesting, they are like DSP's ? (time alignment, EQ, crossover?)
    AMD sempron 140 (underclocked to 1.8Ghz) - foxconn 740G motherboard - 2GB DDRII - 320GB HDD (Laptop) - Power inverter - Lilliput 8 inch LED LCD... project under test...
    ride: Ford Taurus 1988 SW
  6. #126
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by masaki View Post
    Yes they are DSP's. 2 boards are 4 channel DSP and one is Input board(optical/coaxial). Check for miniDSP...
  7. #127
    Nov 2009
    Peru
    thanks, really, really interesting... please write a review if you can test it...
  8. #128
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Im make only few minute test to configure boards and see if all work ok.
    They are very easy to setup when you connect all together and upload right configuration settings and all changes are done online...
  9. #129
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Long time ago Im update my thread and Im change few things...
    First Im change brake pads and rear discs:
    Because my carpc has stop working Im decide to buy and build new one:
    First Im take my old AM/FM radio device and little modify it:
    Then Im add CANUSB device which get CAN data and will be used for diagnostic and steering wheel commands:
    Put all into case:
    DVD device for MP3, Audio CD, Video CD(Divx and other formats), DVD Video, DVD Audio:
    Mounted CANUSB and GPS into case:
    All components:
    Then Im figure out that my Intel SSD has die too and Im replace it with new one:
    Closed case:
    All connectors which I need it(Wifi, GPS, USB2, USB3, eSATA, optical audio out, CAN, Video...) are here:
    And mounted case:
  10. #130
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    So need to work on ...
    What to replace? Tomorrow I will replace the steering wheel with a new multifunction steering wheel...
    First Im find a new spiral cable because the original is missing three contacts:
    Steering wheel:
    The new steering wheel seems to have enough buttons to operate the new digital dashboard
  1. My Fiat Stilo 99% complete (Lilliput in Dash)
    By antofa007 in forum Show off your project
    Last Post: 06-03-2010, 01:42 PM
  2. Fiat Brava OBD-II Compatible?
    By Pharazon in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-22-2006, 11:12 AM
  3. My First Carputer..fitted in a Fiat Bravo (UK)
    By Daz155HGT in forum Show off your project
    Last Post: 10-22-2006, 07:57 AM
  4. Microsoft, Fiat Announce In-Car Computers Partnership
    By uxu in forum General Hardware Discussion
    Last Post: 07-19-2004, 07:45 PM
